Question about Samsung SCH-i730 Pocket PC
Touch screen defective,
The stylus touches a spot, it only affects a site somewhere over/under/beside the desired spot. it is worse on the lower half of the screen, when trying to write. everything I try fails. HELP! i can't afford to buy another one. can i get the screen changed, or how can it be remedied?
  • 1 more comment
  • eww245 Aug 25, 2008
    I seem to have the same problem.In the last few 2 days I am not able to bring up the onscreen keyboard, when I tap there i always seem to open or hit something a quarter inch above.
    When i am in any tabbed menus i have to tap each tab farther and farther down the screen, if that makes any sense.
    I have tried to realign the screen several times but it hasn't helped.
    At this point I am at a loss on how to fix this.
  • Anonymous Nov 06, 2008
    yea, i can't tap the bottom row anymore
  • travis_stein Dec 19, 2008
    I have the same problem... when i try to write something at the bottom of the screen, it writes an inch above... idk why. i calibrated it many times but wont work. i cant eve use the tiny icons at the bottom anymore... how can i fix this problem? i need to know! please email me the solution! email: travis_steinen2000@yahoo.com
Same problem here. Certain areas on the bottom of the screen dont work at all. Other areas I have to tap the stylus 20 times or more an hopefuly it catches. I wont be buying another phone from samsung.
Posted on Oct 12, 2008
HTC or Motorolla? Which one is better?
I have an HTC Touch and the touch screen stopped working many times.
My girlfriend got an HTC Desire Z and the screen stopped working the same day she got it.
I now own an HTC Incredible S and so far I haven't got any problems yet, beside the volume button being in the way.
They are very nice phones, as long as the touch screen dont fail.
Aug 09, 2011 | HTC Touch P3450 Smartphone
Touch screen not working only allowing me to access one item on the front screen and the inside screen is cut in half
Hi, the problem might be from different areas, like the touch screen or from the flex of the phone.
due to the cut half display,might has affected the touch pad. You will need to replace the cut half screen to see if the screen is attached to the touch pad.
Also the phones touch screen might not be working because there might be a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
Have a nice day.
Sep 03, 2010 | LG enV Touch VX11000 Cell Phone
My touch screen froze, so I did a soft reset. This didn't work. So I did a hard reset. All seemed to be going to plan until the 'Align screen' appears. I align the screen as instructed but instead of going...
Whenever you do the alignment touch the spot on the screen with the stylus and hold the stylus on the mark until it moves to the next corner.... this may work
Nov 28, 2009 | HTC Touch HD Smartphone
Touch screen problem
try touching the required spots with your stylus
Jun 13, 2009 | Handmark Software MobileLists (950142) for...
Samsung sch-i730 touchscreen problem
use buttons to go to start,settings,system,screen then click align screen
Jan 17, 2009 | Samsung SCH-i730 Pocket PC
Not working
defective most likely return it for another one.
Jun 16, 2008 | Nintendo DS Lite Console
Typing dots when touching with stylus the Alphas and #s spot.
Try the below
1.Recalibrate the touchscreen, repeat several times
2.Turn off write anywhere on the screen
3.Cleaning the edges of the screen under the bezel (metal casing) by sliding a business card about 1/8 inch under the cover.
Hope this helps...
May 16, 2008 | Palm Tungsten E2 Handheld
Touch screen half loading only
Try uninstalling the TS from the control panel-system-devices (hardware).
Reboot and reinstall the drivers when asked.
The driver must match the OS.
The TS may be defective, does it operate proper on another Pc?
Mar 14, 2008 | Computers & Internet
Touch Screen does not work at all
My touchscreen was acting batty, not responding where I was touching. The solution for me was to:
1. remove my screen protector
2. Take a piece of paper, fold it in half, and scoop under the lip the case where it holds the touchscreen in to fish out debris that were distorting how the digitizer recorded.
Nov 14, 2007 | Palm TX Handheld
Touch screen problems
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend. http://www.nintendo.com/consumer/systems/ds/trouble_screen.jsp#touch ============================================= Touch Screen doesn't respond or is inaccurate when touched * Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen. * Use only licensed Nintendo DS styluses and screen protectors. * Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens. * If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen. * If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen. If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
Jul 20, 2007 | Nintendo DS Console
Samsung SCH-i730 Pocket PC Logo
186 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
