I have a system error e071 on mf8180c image class.
  • wvwkjones1 Jul 25, 2008
    Internet Explorer Script Error
    Line: 1829
    Char:1
    Error:0
    URL:res//leframe.dll/presumedlg
  • 20 Answers
Hi, as per the manual it says
E071 ITB home position sensor fault
Solution
Check the connector of the ITB home position sensor.
Replace the ITB home position sensor.
Replace the DC controller PCB.
Posted on Jul 25, 2008
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
How to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon color imageclass mf8180c, Iam getting '' SYSTEM ERROR E071
I had the same error message E071. Had to call out an engineer who diagnose the Drum 701 was leaking toner - this got on the electrical contacts at the bottom of the drum. He cleaned the contacts on the drum and in the machine - put my old Drum in there and all is OK. The drum was 9 months old and not had much use so I am trying to get a replacement from Canon under warantee.
Apr 06, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
CANON i-SENSYS MF8180C
hi happy new year
E071 ITB home position sensor fault Check the connector of the ITB home position sensor.
Dec 29, 2008 | Office Equipment & Supplies
Canon MF8180c
E071 error stands for ITB position sensor fault,so you may try to check if the ITB belt is ok, if there is no paper left overs or similar, but this error can occure when the main board ( dc controller ) is defective.
Nov 01, 2008 | Canon imageRUNNER C3200 Color Printer
550 people viewed this question
jasbo
jasbo
