Back to:
Tags:
LG WM-2277HW Front Load Washer
Leaking door
posted by elg624 on Jul 25, 2008
my lg front loader is leaking water from the bottom of the door
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 25, 2008
Thanks for Trying (70)
cresguy
Rank:Wiz Wiz
Rating: 79%, 30 votes
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Rating Locked! (?) elg624 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on leaking door:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
Machine just gone dead (15 months old). Power is getting...
i NEED TO FIND OUT HOW TO REMOVE TOP OF WASHER ENCLOSURE...
OE comes up checked both drain hoses doesn't help
sir i hav purchased lg mobile ie c2500 ..while purchasing...
Wolfster- Thanks for providing the perfect solution. I...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
