Question about Xerox WorkCentre M15i Laser Printer
Paper Feed Wheels
When we load a document to be faxed or copied the wheels squeak in the loader. Any suggestions?
  • 2,072 Answers
Yes thats easy to fix.
Unplug the machine, unplug the connector fromt\ the document feeder to the scanner. One white molex connector with 2 thumb screws on back.
Lift the document feeder up and out, and lay it upside down on a table or work surface.
On the bottom side you will see a shiney white strip about 12 inches long and 2 inches wide, it has 2 holes, one on each end to access a couple of screws. Just remove it from one side, just held on with two sided tape. Then roll it back. Under there you will see I think 4 maybe 5 small black plastic rollers. They are held in with one screw attached to a small metal bracket. Remove the screws and plates for all the rollers, remove the rollers and take them off the shafts. Clean and very lightly lubricate those small metal shafts, and reinstall the rollers, etc. The white strip will stick back to the side you peeled it off of.
Those rollers are where the noise is coming from.
Posted on Jul 25, 2008
Will not manually feed paper
Are you talking about the document feeder or the copier. On both counts try to clean the rubber wheels above the feed tray, or up on the document feeder with something like windex or a water cleaner. make sure the wheels are dry, and watch to see if the wheels are turning. If wheels are turning when you feed you need new wheels, sometimes you can rough them up with a grit nail file, or sandpaper.
Apr 30, 2014 | Brother MFC-8460N All-In-One Printer
ImageRunner 1023iF auto-feeder stops mid-way through document. Pick-up and feed Wheel continues to spin for a moment, then stops and gives "Check Document" error. I have fed a card through the...
It can be the problem in sensor flapper on ADF tray ( small nose that is pointing out ). Maybe it doesn't works fine or in the middle of the copy from adf the paper is too far away from the sensor.
Also can be the problem of ADF pickup clutch or You are using unappropriate paper type- try with normal A4 80g/m as original to copy from adf.
Hope that something of this helps You!
Jun 02, 2011 | Canon imageRUNNER 1023iF Black and White...
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
Paper wont feed through on my canon fc224 photocopier
On these fax machines the most component that gets the most usage are the feed rolls.
Even though they are hard to find and hard to reach, using a flashlight one can view the surface of the feed wheels. By inspecting the surface, they may appear to be shinny instead of the normal feed wheel surface tracks.
Either the wheels need to be replaced or cleaning the surface might get a little reliablity, eventually they may need to be replaced.
Some feed wheels have a lower or they might be on the upper part of the drive train, where they have a square rubber pad.
This is especially true with document feeders, the most common part that wears out.
These pads or, arm tips wear out and need to be replaced.
I hope this helps out.
Oct 17, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Canon NP 6050 Paper Feeder won't feed
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
Apr 01, 2009 | Canon NP 6050 Copier
Lexmark x7550 document feeder not taking pages of document for fax
Try cleaning the Feeder wheels that feed the paper in. Use a Dry cloth to wipe away paper fibers. They can cause the printer not to be able to grab the paper.
Nov 03, 2008 | Lexmark Office Equipment & Supplies
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
SCX-6320F Samsung
Dear ,
Do u need to pull out the paper or  it comes on it's know,
Oct 10, 2007 | Samsung SCX-6320F All-In-One Laser Printer
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Xerox WorkCentre M15i Laser Printer Logo
194 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
