NO ENGINE TOLD ! 2.0 OR 2.5LITER?????????
TH 8TH DIGIT OF YOUR VIN TELLS YOU WHICH ENGINE IS THERE, PLEASE TELL THAT FIRST.
The alternator is overcharging. what makes you think so?
a meter test.?
scan tool shows DTC that said that>?
OK JUST FLICKER,
lights flicker, what light, heads, or charge lamp error
or what? (i guess all)
putting in 3 wrong alternators is painful , there are 2 used, here. on 2 engines
one is pcm controls, other is not.
The 2 engines and matching ALTs:
DURATEC -VE 2.5LITER ONLY
ZETEC-VCT 2.0L ONLY
THEY ARE NOT THE SAME. ALT ! NOR ENGINES
DURA HAS 3 FUSES TO BLOW. BOTH ALTS USE THESE FUSES
F30-CJB. 7.5a, CENTERAL JUNCTION BOX.
and F2 =BJB, 15AMP BATTERY JUNC. BOX BJB
AND FB 175 AMP
THE REG IS INSIDE THE ALT HERE, NOT PCM
DID YOU REPLACE THE ALT WITH THE NEG LUG ATTACHED, IF YES, THE 175AMP FUSE IS BLOWN BOOM
ZETEC USES PCM REGULATION
AND SAME 3 FUSES TO FAIL, 1,2,3..
THE 175 FUSE MUST BE GOOD. TOO.
THE CORRECT GENERATOR FOR YOU ENGINE MUST BE USED
THE DURA and zetec alternator gens can NOT be mixed up here ever!
best way to buy any alt is by VIN # code or fail 1/2 the time or even 3times in row. or 175amp is blown
if buying over the counter (a new alt) tell them there 2 kinds used in 2000, tell them the vin 8th code.
