Hardisk problem my harddisk does not detect but computer starts only display coming but system does not boot.monitor displays harddisk status bad replace harddisk.
    Problem Solver:
  • 21 Answers
With a bad hard drive you have a few options. If you have valuable data on the drive that you want to retrieve, you could make a BartPE disk from a working PC. Their website has step by step instructions on how to do this. this way you can boot to a CD and browse around your files and copy them over to an external hard drive, finger drive, or floppy disk. Just google BartPE. Alternatively you can go buy another drive from bestbuy, install it as a master with the defect as slave. Install windows on the new and once it's all up try to browse the old drive to recover the files.
If there is nothing on the drive you want, toss it, buy a new one and reload windows.
Posted on Jul 25, 2008
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
Computer wont boot up, power light comes on but wont recognize monitor. just before it started doing this , the computer would come on and start to boot up, when the windows status bar came up the computer...
there are many reasons for this problem i want u to tell me that did u install any program before this happened or power failure leading to immediate shutdown.
problems can be
1.there might be problem with due virus
2.it might be a problem of hardware failure of harddisk
3.it can also be that there might be bad sectors created on hard disk
right now what solution i can provoide is if boot from cd and try install fresh copy of operating system.u will have option of formatting only the c drive keeping rest of the drives with your data
Jul 06, 2010 | E-Machines (308714) Motherboard
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
Monitor says: "Out of range"
This means that a video signal has been detected but it is beyond the range for display. As an example, if the monitor can only display 1024x768 and you send it a signal at 1280x1024, you will get that message. Try to downsize the display settings on your computer system until the monotor works.
Dan
Nov 06, 2009 | BenQ FP767 17" LCD Monitor
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
Operating system not found
When you power up the computer press F1 ore F2 or "del" key toenter in bios then check your hardisk is detected or not.
If not then if you have desktop open cpu cabinet then reconnect power cable and ide or sata cable to harddisk also check your harddisk is set to master.
Jul 29, 2009 | Microsoft Windows XP Professional
Disply problem
I guess your computer is not booting.
  • Fix and tighten your RAM into the slot properly also clean the dust on the RAM with a soft cloth if any
  • check the cables for the HardDisk and CD Drive,they should not be lose
  • Take out all the USB connection [Flash/Pen drive,mobile,printer etc.]Try n change the Keyboard and mouse also.
  • Your computer Should Boot now.
Jun 04, 2009 | Intel D845GVSR Motherboard
Harddisk not detected
Hi, I think that your os has been crashed. So insert your disk and boot your system and check that your BIOS will boot from CD (Boot preference - CD ROM). And install a fresh copy of your os. Let me know the result.
Nov 29, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hi I am fairly good with computers but i dont know how to fix this problem. My advent 7113 laptop turns on the power light comes on and they the fan starts but am not sure if the harddisk boots. Then...
It sounds like Either the onboard video card or the LCD controller has gone bad. To verify which one connect a monitor to the VGA adapter on the back of the Laptop. You may also have to hit a key combination to swap displays (Usually <Fn> + <F5> but may be different the keys usually have an offset that indicates its function.
If the Monitor displays the same black and white anomaly then the vid card went bad, if it displays a normal screen your LCD controller is faulty.
Either problem would likely need service from an experienced technician
Hope this helps
Dave
Nov 07, 2008 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
