Question about Canon MultiPASS MP700 All-In-One InkJet Printer
Waste tank almost full on Canon i320 printer - Canon MultiPASS MP700 All-In-One InkJet Printer
  • a_k_d_o Aug 18, 2008
    I have a Canon PIXMA MP170 All-in-One InkJet Printer and the 'Waste Ink is near Full' sign keeps appearing. I cannot find a tank to empty - where might it be? Have performed deep Fine cartridge cleaning but that did not help.
What container? There are several containers inside the printer.
Posted on Aug 02, 2008
  • 446 Answers
Waste toner must removed after a period of time open up your printer and you can see a small container inside. dispose properly the toner inside and clean the container with vacuum, do not use water, gently reinstall again into your printer and reset.
if you cannot find the location of the waste box consult your manual for proper location.
Posted on Jul 25, 2008
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Waste ink tank is full. Where can I buy one?
Hello there please try
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Aug 05, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma ip1000 dismantle
Hi there you can try
Temporary Fix
  11. You are done.
Jul 09, 2009 | Cannon Canon i960 Photo Printer
Waste ink absorber is full
Temporary Fix
  11. You are done.
Mar 24, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Waste ink absorber is full-canon pixma ip1000
Temporary Fix
  11. You are done.
Feb 03, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have a canon i320. the light flashes green, orange. does not print. I tried resetting the printer but to no avail. What is the next step?
it means that waste ink is full,
do this:
How To: Reset Canon Printer
I have try to find out how to reset many canon printer in my office. I
was try to googling to find the best way and quickly how to reset it.
And in google I was found two way how to do it. With Manual Reset and
with Software reset. I will give some advice how to do that with first
method, yes manual reset.
On this point we will do this with my Office printer, Canon i255, i320, ip1000.
For i255, i320
Waste Ink Counter Reset.
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or Step This Step
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should
be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.)
should be green.
6. Release both buttons.
Canon PIXMA iP1000
Waste Ink Counter Reset Manual for Service mode
be orange.
should be green.
Nov 30, 2008 | Canon BubbleJet i320 Printer
Ink Waste Tank Almost Full on Canon i320 printer
Hi, This procedure should work.
Step 1 : Manual for service mode
3. Connect power.
or
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Jul 25, 2008 | Office Equipment & Supplies
Canon pixma ip3000
This should do the trick!
i320 waste ink counter reset.
3. The indicator should be green.
3. Press and release the RESUME button , the indicator should be orange.
4. Press and release the RESUME button again, the indicator should be green.
5. Release both buttons.
6.Connect the printer to PC.
7.Open General Tool software,choose ¡°USB PORT¡±.
8.Choose ¡°SET DESTINATION 1 ¡±,OK!
You can download the software at: http://www.it0577.com/yezmao/i320.exe
Dec 03, 2007 | Canon i80 InkJet Printer
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon MultiPASS MP700 All-In-One InkJet Printer Logo
179 people viewed this question
old marine
old marine
