Question about Microwave Ovens
Broken microwave I tried the door trick, raising the door, and it didn't work. No heat or rotation. Any other suggestions?
  • Karen sue Jul 29, 2008
    Thank you for your response. How do I find the door switch and how easy is it to replace?
  • Microwave Ovens Master
  • 9,098 Answers
Yes, please refer to my previous message here, where I discuss door switch trouble, sources for exploded views, parts, etc.
Even though the door trick didn't work, you do have a bad door switch or door switch mount.
That is how your microwave can be fixed.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 25, 2008
  • William Miller
    William Miller Jul 29, 2008
    Not too bad. You remove the outer cover and then look in the area where the hook-like door latches go into the body of the oven next to the control panel.
My r-1874 microwave unit will not run unless a small wood handle is put under the door. This has worked in the past but now this little trick does not work. Any idea the part that not working properly
I would say the mount for your bottom or top door switch is loose, misaligned, or broken. And you may have a failed door as well. See my help file on door switches here.
Slamming the door and opening the door while it's cooking instead of hitting the "Stop" pad before opening it both contribute to door switch trouble.
The service manuals covering this model are here and here.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Feb 16, 2014 | Sharp R-1874 Convection/Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
GE Advantium oven (6 y.o.), has hot spots, makes unusual noise
The drive to the carousel is broken...and what you hear is the drive trying hitting the bottom of drive shaft* (cheaper to replace then fix)
Dec 11, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
Nov 15, 2008 | Sanyo Microwave Ovens
Sanyo-Microwave oven-start up
This is usually caused by either a bad door switch, a loose door switch mount, or misaligned door hinge.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Aug 07, 2008 | Sanyo Microwave Ovens
Microwave is not working
Yes. This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a misaligned door hinge.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 06, 2008 | Frigidaire FMV156DC Microwave Oven
Broken microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 23, 2008 | Microwave Ovens
The turntable keeps rotating when the dooe is open - Panasonic T994SFR
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
Jul 14, 2008 | Panasonic NN-T994SF Microwave Oven
Microwave oven - Amana Model MVH220E
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | Amana MVH220E Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
