Question about MSI 865GM2-LS Motherboard
Usb system says that usb has no problems, but whenever i plug something in, it does not show on my computer
  • southcali Jul 26, 2008
    I dont have it. I got the computer out of a pile of pc's from my mother's business that went out of business... so i have nothing to work with. it had win 2000 pro on it. i installed xp pro. and it could not find the nic, vga, or audio drivers.... i looked on the net and found a few at MSI and Intel. enough to get the pc running smoothly and back on the net... also updated the bios.... so here i am, device manager says no problems with usb, but when i check sys info, i get this under conflicts:
    I/O Port 0x00000000-0x00000CF7 PCI bus
    I/O Port 0x00000000-0x00000CF7 Direct memory access controller
    IRQ 16 Intel(R) 82865G Graphics Controller
    IRQ 16 Intel(R) 82801EB USB Universal Host Controller - 24D2
    IRQ 16 Intel(R) 82801EB USB Universal Host Controller - 24DE
    Memory Address 0xA0000-0xBFFFF PCI bus
    Memory Address 0xA0000-0xBFFFF Intel(R) 82865G Graphics Controller
  • Tim Babcock
    Tim Babcock May 11, 2010
    Did you install the USB driver from the CD that came with your motherboard?
  • 2,794 Answers
Here is the download site
but I don't see anything that matches the number given. You can find it by processor socket type and processor used.
Posted on Jul 26, 2008
Olympus fe 20
Look inside the DCIM folder. You should see another folder, then the pictures inside that inner folder.
Better yet, don't connect your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jun 03, 2013 | Cameras
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
Dear Sir, When i inserted by Pen drive in my laptop it shows a message " USB Not Recognized" & then i tried the same in various PC's & Laptops but the same message has come. What shall...
Are you getting a "USB device not recognized" error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn't work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn't work!
You may also see in Device Manager that the device shows up as an "Unknown Device".
So how did I finally fix the problem? Well, apparently it's a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
Mar 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a Craig mp4 .. but I'm trying to use it but i do not how .. because when i connect it to the computer it is not recognized by the computer please help me
Hi, Are you getting a "USB device not recognized" error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
usb device not recognized
unknown usb device
Have a nice day...
Mar 02, 2011 | Audio Players & Recorders
Whenever I plug a thumbdrive I now get a bluescreen warning about XP shutting down to protect my computer and then the computer reboots. This happens whether I plug in either my Sandisk or PNY thumbdrives...
Usually blue screen errors are associated with hardware. Since you are experiencing problems after migrating the motherboard it has to do something with it.
Try removing the Jumpers and cables associated with the usb ports on your motherboard and refix them back. This will probably help you fix the problem (also make sure your jumper and cable configurations are correct - they can usually be found on *********** board manual)
If the problem still persists try taking the whole machine apart and refix it again.
Hopefully this will help you. Best Regards NextDoorNerd
Jul 28, 2010 | Intel Desktop Board D845GERG2 Motherboard
VX-1000 problems
Start- right click my computer - properties - hardware - device manager. Click on the + signs to expand links, find your camera, is there any question or exclamation marks showing, is so, right click & see what it says.
If nothing shows up as wrong, un-install your cam in device manager, restart your computer,(cam unplugged) when up & running, plug your cam back in & system will see it as new device & install it.
Hope this helps your issue.
Have a nice day.
Oct 01, 2009 | Microsoft LifeCam VX-1000 Webcam
Error message File System Error
Whenever I go to turn on my Philips Gogear audio video mp3 player, it shows the welcome screen but it doesn't go to the GoGear or the updating screens. Also, whenever I plug it into my computer through the USB cord, the charging screen doesn't show and it does not show that it is connected on 'My Computer'
Aug 20, 2009 | Philips GoGear SA3125/37 MP3 Player
When i double clck on internal storage on my mp705. there are no folder or anything for that matter. it used to show as removable device g. now it just shows a Coby 705
Well, when i first got mine, I plugged it into my computer and opened Windows Media Player, and all my music sync'd with it. When I went to delete and organize my music none of it showed up... A quick way to fix this is to plug it in and have it in USB mode, then go to "MY Computer" and right click the MP4 player or "Removable Hardware" or whatever your computer calls it and click on "Format" and format it, it will take everything off, but then you can drag and drop your files into it and you can access them when you plug it back in... Hope this helps...
Jun 11, 2009 | Coby MP-C7085 MP3 Player
Alesis Multimix 8 USB won't be recognized
There are NO drivers to be installed for this device. Plug in the usb to the device, and the PC once the PC is running turn on the mixer. XP should inform you that a USB Audio Device has been found & installed. Any software you use for rec'ing will let you choose what sound device to use, select USB Audio Codec.
May 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
IRIVER PMP 120
its just the USb isn't enough space for the usb port to fit in, thats all
Mar 28, 2008 | iRiver PMP-120 Digital Media Player
MSI 865GM2-LS Motherboard Logo
102 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
