Question about Microsoft Xbox 360 Core System Video Game Consoles
On my xbox360 my game GRAW will not load any multiplayer maps? it just freezes up
    Problem Solver:
  • 7 Answers
The game you have got ruined on that part. Try cleaning it. Or replace it. Thats all I have sorry but I tried helping.
Posted on Aug 05, 2010
  • 34 Answers
SYMPTOMS Your screen "freezes," or seems to lock up, when you try to play a game, when you use the Xbox Dashboard or the Xbox Guide, or when you wait for the console to start. When this problem occurs, you do not receive an error message, and no lights flash on the console to indicate a problem. on my xbox360 my game - uparrow.gifBack to the top
THINGS TO TRY You can try the following methods to determine the cause of the problem and to try to fix the problem. If you cannot fix the problem yourself, you might want to ask someone you know for help. You can also contact Xbox Support for help. For information about how to contact Xbox Support, visit the following Xbox Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top
Determine whether this is a one-time issueFirst, consider whether the problem has occurred multiple times. If this is the first instance, the problem might not occur again. To determine whether this is a one-time problem, turn off the console, and then turn it back on. If the problem does not occur again, additional troubleshooting may be unnecessary. uparrow.gifBack to the top
Determine whether you can return to the Xbox DashboardUse the Guide button on the controller to see whether you can exit from the game to the Xbox Dashboard. To do this, press Guide, and then press the Y button. If you can exit the game, the problem may be caused by the game. Back to the top
Make sure that your Xbox 360 console is appropriately locatedIt is important to keep your Xbox 360 console in a cool, dry, well-ventilated area. Do not put the console or the power supply on a bed, on a sofa, or on any other soft surface that may block ventilation openings. If your Xbox 360 console is in a poorly ventilated location, turn off the console, and then move the console to a location that has sufficient ventilation, such as a table or an open shelf.
Keep your console away from heat sources, such as televisions, computers, monitors, and other electrical devices. Turn off the console, and then move it away from the heat source. Or, turn off the device that is generating heat, and then move that device away from your console.
For more information about how to locate the Xbox 360 console, see the Xbox 360 instruction manual, or visit the following Xbox Web site: http://support.xbox.com/support/en/us/xbox360/hardware/console/setup/positionyourconsole.aspx (http://support.xbox.com/support/en/us/xbox360/hardware/console/setup/positionyourconsole.aspx) uparrow.gifBack to the top
Determine whether an accessory is causing the problemTurn off your console. Remove all the accessories that are attached. This includes the Xbox 360 Hard Drive. Then, turn on the console to see whether the problem still occurs. • If the problem does not occur when the Xbox Hard Drive is disconnected, try clearing the Xbox 360 Hard Drive cache.
For more information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base: 971755 (http://support.microsoft.com/kb/971755/ ) How to clear the Xbox 360 console cache • If the problem occurs when the Xbox Hard Drive is connected, and if clearing the hard drive cache does not resolve the problem, create a new gamer profile. Then, test to see whether the issue still occurs. If the issue does not occur when you use a new gamer profile, the problem may be related to the original gamer profile or to saved game information for one or more games that are associated with the original gamer profile. To verify this possibility, delete the saved games for all games that show this problem when you use the original gamer profile. uparrow.gifBack to the top
Determine whether the problem occurs for online games onlyTest to see whether this problem occurs only when you play Xbox LIVE. To do this, play some games offline. If the problem occurs only when you try to use Xbox LIVE, the problem could be related to your Internet connectivity.
For more information about how to troubleshoot problems that occur for online games, click the following article number to view the article in the Microsoft Knowledge Base: 909817 (http://support.microsoft.com/kb/909817/ ) When playing a game on Xbox LIVE, you experience lag uparrow.gifBack to the top
Check your console settingsIf your console is a PAL console, try to use a setting of PAL 60. For more information about how to set your Xbox 360 console to PAL 60 Hz for specific situations, click the following article number to view the article in the Microsoft Knowledge Base: 917304 (http://support.microsoft.com/kb/917304/ ) While attempting to play an Xbox 360 Game, your screen becomes black or distorted uparrow.gifBack to the top
Determine whether the disc that you are using is causing the problemTry to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using causes the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
For disc-specific issues, check the disc for any visible signs of damage or dirt. Hold the disc by the edges without touching the top or bottom surfaces with your fingers. Clean the disc by using a soft cloth. Lightly wipe from the center outwards. Do not use solvents or chemicals to clean the disc.
If this problem occurs only when you use the first disc that caused the problem, and if cleaning the disc does not resolve the problem, search the Microsoft Knowledge Base to determine whether that particular game disc has any known issues. To search the Microsoft Knowledge Base, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) In the Search Site box, enter the text of the error message that you received, or type a description of the problem. Then, click Search
Posted on Jul 19, 2009
  • 3 more comments
  • Neen39 Jul 19, 2009
    SYMPTOMS
    Back to the top
    THINGS TO TRY
    http://www.xbox.com/support/contact http://www.xbox.com/support/contact)
    Back to the top
    Back to the top
    Back to the top
    http://support.xbox.com/support/en/us/xb... http://support.xbox.com/support/en/us/xb...
    Back to the top
    971755 http://support.microsoft.com/kb/971755/ ) How to clear the Xbox 360 console cache
    Back to the top
    909817 http://support.microsoft.com/kb/909817/ ) When playing a game on Xbox LIVE, you experience lag
    Back to the top
    917304 http://support.microsoft.com/kb/917304/ ) While attempting to play an Xbox 360 Game, your screen becomes black or distorted
    Back to the top
    http://support.microsoft.com http://support.microsoft.com/) In the Search Site box, enter the text of the error message that you received, or type a description of the problem. Then, click Search
    SYMPTOMS
    Back to the top
    THINGS TO TRY
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    SYMPTOMS
    Back to the top
    THINGS TO TRY
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    SYMPTOMS
    Back to the top
    THINGS TO TRY
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    SYMPTOMS
    Back to the top
    THINGS TO TRY
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
    Back to the top
On black ops i can only play zombies,multiplayer maps freeze except 2 help!
That sounds like a problem with the disc itself. It either needs to be cleaned or buffed to get any scratches out.
Jul 02, 2011 | Microsoft Xbox 360 Console
Jillian michael game freezes and makes a noise when multiplayer
some times the game gets messed up because of a scratch
Jul 16, 2009 | Nintendo Wii Console
For some reason i can play sierra 117. also the catch skull is mi
This sounds similar to what happened to me, except I couldn't load some multiplayer maps.
If you know someone that recently bought Halo 3,(within a week) ask him/her to return it with your defective game in the case. He/she will receive a new unopened Halo 3, and you can take your friend's recently opened copy of Halo 3.
If you don't want to be cheapskate, you can borrow Halo 3 from a friend, and save it on your hard drive. After that, you can use your defective disc just to play the game. Unfortunately, if you save it on your hard drive, it supposedly makes the game slower when searching for multiplayer matches online, and other things.
If you don't care about saving money, you could buy another copy of Halo 3.
Jul 14, 2009 | Microsoft Xbox 360 Console
Map Pack 1 Not fully Loaded
Try to setup a private match and see if these new maps are on the list. Have you tried to play in a game mode with this problem?
Mar 27, 2009 | Dmm Call of Duty: World at War
Xbox Live Ghost Recon Advance Warfighter drops me from multiplay
the connection to the host may be to weak or faulty in some way
Jan 19, 2009 | Ubi Soft Entertainment Ghost Recon...
Xbox360 freezes up in the same spot every time on a certian game
that happened to me it was the eye in the xbox console so i put in a cleaning disk and cleaned the game disk,.i had a very small scratch on the disk so i cleaned it well and i never had that problem again,. Hope it works
Nov 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Core System Video Game Consoles Logo
125 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
