Question about Mitsubishi WT-46805 46" Rear Projection Television
PCBs/Fluid OK, so, where are the PCBs and if I see fluid, what do I do about it? Are there replacements and how much $ do you think we're talking about? Thanks! Rudy
  • 927 Answers
Posted on Aug 07, 2008
If servicing records show that equipment manufactured after July 2, 1979, was serviced with fluid containing PCBs, may I still assume the equipment is non-PCB?
depends on the level of PPM PCBs
and questionable equipment used to manufacture fill fluid containing PCBs after any year
at a higher than industry stds .....should be de contaminated or disposed of correctly
Aug 02, 2016 | XPLOSIV Pop Cap Games - Con/Term...
What assumptions apply to silicone-filled transformers manufactured prior to July 2, 1979 and after July 2, 1979
Silicone dielectric fluid was manufactured not to contain PCBs. There is no assumption applicable to transformers known to be silicone-filled while in use, regardless of the date of manufacture. These transformers are regulated based on their actual PCB concentration. It is possible the transformer could have become contaminated during servicing with fluid containing $50 ppm PCBs
May 26, 2016 | Hotpoint Repair PCB / Module for WF530...
Urgent need for diagram/schematic 2005 Ford Escape XLS AWD 4 cal.
You talking rear differential? I would check the fluid level. There should be a plug where you can check fluid and add if needed. If you take the plug out and fluid tries to run out, put the plug back in, the fluid level is ok. In the old days, I'd stick the tip of my index finger and bend, If I could touch the fluid, I considered the level to be ok. I believe the spec I saw said about 3/16 below edge of hole was ok.
Oct 30, 2017 | Ford Escape Cars & Trucks
Slow to engage in D, but engages readily in lower gears, 1 & 2. Sluggish engagement into Reverse and sometimes requires some throttle. Transmission fluid level and consistency look right. What is the...
It sounds like it is time to service your transmission. Even though your level and fluid looks ok your filter can be dirty (clogged). If you take it to be serviced have them drop your tansmission pan and replace your filter, do not let them talk you into using a procedure that sucks old fluid out and put new in. This will cost you more in the long run.
Feb 28, 2011 | Ford Econoline Cars & Trucks
What kind of power steering fluid is used for a 1998 ford mustang (v6)? Is Dot 3 brake fluid ok?
Do not use DOT 3 brake fluid in a power steering pump. It will eat away all of the seals and hoses. If you are looking at power steering fluid, any power steering fluid will work. If we are talking about brake fluid, Then yes use DOT 3 brake fluid or DOT 4 break fluid. The top of the master cylinder should tell you which to use.
Jan 03, 2010 | 1998 Ford Mustang
What is the average time it will take to change brakes and brake fluid on a 2006 Scion Tc?
If you are talking about changing the brake pads on the vehicle all the way around it would take approximately 2 hrs. To change the brake fluid about another hour or so.........but not sure as to why you are going to change the brake fluid. If you not sure if the brake fluid is good or not go to your local parts store and get the brake test strip test kit and test your fluid to see if the integrity of it is still ok. Most of the time brake fluid will last a long time without any problems.
Dec 03, 2009 | 2006 Scion tC
Power steering fluid leaking out
yes that is possible, and no the fluid is not supposed to be in those boots. the part you are talking about is your steering rack- if fluid is comming out of the boots, that means the seals in the rack are damaged. they are not servicable, the rack must be replaced.hope this helps and good luck
May 25, 2009 | 1995 Chrysler LeBaron
The Malfunction light is showing on the dash of my toyota Highlander. According to the book it could be empty fuel tank (not), loose fuel cap (not) or automatic transmission problem. - How do I check the...
In some cars , you have to take it to the dealer to check and service the transmission fluid. Don't ask me why. I think they are crazy. But I know there are some cars that only a dealer can check the transmission fluid. I think your may be one of them. Check your owners manual to see if it says anything.
Feb 01, 2009 | 2002 Toyota Highlander
Mitsubishi WT-46805 46" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
