Question about Samsung DVD-VR357
Can a user swap in a replacement DVD drive?
The DVD drive appears to have died. The tape deck is OK and I confirm it plays a tape. The DVD drive just "clicks" and we never get past "Load." I've built plenty of PCs and adding/replacing all kinds of drives is a no brainer. Will the replacement drive have to be a certain model?
  • 781 Answers
Any type will do but please ensure it has dual layer burning and comes complete with drivers
Posted on Aug 08, 2008
Replaced belts on both drives but it still won't play or turn tape at all. Any ideas?
With the belts off, hit the rewind, forward and play switch. Check to see if the deck reels spin without the tension of the belt. If they do spin without the belt then you wll need to replace the motors. They are weak and dying. If not spinning at all with or without the belt then you need to check the motors independently to see that they work with a power source. If that is the case then you need to identify the wire or power board that is not sending power. Hope this helps.
Apr 19, 2016 | Audio Players & Recorders
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Not all cd tapes play clearly out of 12 tapes ,4 sound ok ,8 soundwrak
Are these all commercial pre-recorded tapes? Or are they tapes that were recorded at home? Is the tape deck one that the tape loads in from the short side and must be flipped around to play the other side....or is it one that the tape loads in with the tape facing in and is auto-reversing? Pre-recorded commercial tapes should work on most machines without problems. Home recorded tapes can be a problem, especially on the type of deck that the tape must be swapped over to play the reverse side. Many users use C90 or C120 tapes to home record. These tapes are thinner than normal tapes and are prone to getting overly tight and then can break and/or stretch. This causes jamming in the deck and distortion of the playback.
Jan 18, 2015 | JVC Car Audio & Video
Circuit nad 6325
replace ALL belts in the deck (there are 3) the deck is sensing that the tape reels aren't moving and protecting it. that should solve your problem. do not use elastic bands, they will foul and destroy the gear driving the capstan.
Mar 21, 2014 | Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
What is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the mechanicals....is the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Rob
Mar 24, 2012 | Audio Players & Recorders
I have distortion of playing tapes.
Degraded tape, dirty heads (clean with acetone and Q tip but don't get on plastic), dry coupling capacitors.This assumes that the distortion that you refer to is dirty or fuzzy sounding audio.
If a new tape, recorded and played back, sounds ok then your electronics are in good shape. That means your tapes are junk. If cleaning heads takes care of it, well that's pretty obvious. If your capacitors are dried out you will need to bring it in to a repair shop.
Apr 20, 2009 | Audio Players & Recorders
Yamaha k-720 cassette deck
No play but fast forward and reverse work ok--yes it is the drive belt. I disassembled the unit to find that the belt is actually sticky and stuck to both weighted flywheels, the drive motor pulley and managed to stick to itself. The drive motor is warm from trying to turn. Now, anyone know where to find the belt??
Nov 28, 2007 | Audio Players & Recorders
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
Samsung DVD-VR357 Logo
259 people viewed this question
Henry  Thomas
Henry Thomas
