Question about Electrolux Washing Machines
( Electrolux W4180H ): screen is turned off althought there is voltage in its receptical
ELECTROLUX W4180H , THE PROGRAME IS RUNNING OK BUT GIVE AFTER 2 MINIUTES MOTOR TO HOT
THE MOTOR IS OK
WHAT IS THE PROBLEM?
Posted on Sep 23, 2010
  • tiger455 Nov 05, 2017
    check for temperature sensor or the pcb that carrying temp. signal
Looking for W4180H frequency inverter/motor control
guarantee vacuum and sewing center or order directly off of the website
Mar 19, 2014 | Vacuums
Electrolux Ultra Active ZUA3840 error blinking L (or 7)
Sure, Disconnect the two wires going directly to the motor. Then apply line voltage directly to the motor terminals. If motor does not turn it is defective - check the brushes for wear or bad contact. If motor runs then the electronics are bogus.
Nov 28, 2013 | Electrolux Vacuums
Electrolux E52 error code Dryer
Hello drew_wedemey -Typically error code E52 indicates that the unit has a faulty motor. If the drum does not turn freely by hand, then I highly suggest contacting a professional to accurately diagnose the following; motor windings, L1 power supply voltage and the motor thermal protector.
Sep 30, 2012 | Electrolux Dryers
Goldstar black screen
If conventional set and not LCD etc No high voltage is most likely--that area provides 20,000 plus volts to picture tube and also voltages for audio.
To repair or to replace set?
May 03, 2012 | Philips 32RF82S TV
My washing machine and dryer is not working. Where
check the required voltage i think your voltage is different than usa it could be as simple a switch i would look on the back of the machine to see what voltage it operates on and call an electrolux dealer
Apr 12, 2010 | Electrolux EIFLW55HIW Front Load Washer...
When I turn on the rear defrost the radio loses reception. is there a short between the radio antenna and rear defrost
Heated rear windows have a high voltage load, quickest and easy resolve would be to install an inline suppressor to where the aerial plugs into the back of the stereo, available from all car audio store, it will improve your reception also.
Nov 21, 2009 | 2000 Pontiac Grand Prix
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
No picture on tv just blank screen
Sounds like you lost your High Voltage Power source which lights up your screen. If you don't know anything about TV's do not attempt to fix this problem. The High Voltage Power Supply is around 40,000 Volts!
Mar 26, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Loses reception
Is it a water damaged phone or dropped?
May 19, 2008 | Motorola Mobility RAZR V3
Washing Machines Logo
255 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
