Question about Samsung ML 1610 Laser Printer
Online/Error Please, when I turn on the printer, I can listen and see the gear in the top rotate, the online/error light is green. Suddenly, the sound stop and the light go on red and nothing happen. No one page printed. Can you help me? Thank you very much.
  • Anonymous Aug 02, 2008
    i have the same issue did you find a fix?
  • Anonymous Nov 16, 2008
    Sometimes the red light starts blinking and the printer stops printing......
  • 446 Answers
This could probably caused by interrupted spooled jobs that was sent earlier, as i assumed, try pressing the cancel button on the printer itself, or from your pc cancel all documents.
if you cant recover still reset the printer once again and put some paper to finish the pending job that was qued earlier
Posted on Jul 25, 2008
1st see if any paper is jammed.normally these types of printers
has to be open from bottom to remoove piece of paper. u r not able to see from top. see its manual.
after chk reply.
How do I fix TWAIN error? How do I fix Scan Gear error message cannot communicate with scanner?
you need to make sure that your printer is supported by TWIN , you can do that online.
Oct 21, 2015 | HP LaserJet Office Equipment & Supplies
Show picture of carousel rotary for hp 2840
Carousel rotation motor error, only professionals can do this activity,, Pl submit the unit in service center,, online support not suggestible..
Nov 16, 2011 | HP LaserJet 2840 Printer
Online error
problem with Samsung ML2250 laser printer when power on the printer it is blinking green light after few second red light is blinking what is the problem. i am changing the fuser & toner also when i got same problem please help me to give better solution.
Jul 11, 2011 | Samsung ML2250 Laser Printer
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
My samsung ML2010 printer has Error button flashing green
your printer is not inisilize properly. it is a logic card problem.so pls you can repaired it from printer vendor.
Sep 02, 2009 | Samsung ML 2010 Laser Printer
C510 printer displays "994 Service Engine Error". How do you addr
Here you go, courtsey of Lexmark's Knowlwdgebase.
Don
994 Service Engine Error on a Lexmark C510 ID: ENUS21233 If your printer is unable to move the photodeveloper belt to the correct position during printing, a 994 error will occur. However, it may simply be the case that the photodeveloper is either contaminated with excess toner or improperly installed. To test for and resolve this issue, please do the following:
  1. Power the printer off and remove the photodeveloper cartridge.
  2. Rotate the green metallic photodeveloper belt by manually turning the white drive gear on the bottom of the cartridge until the black positioning markers are visible.
  3. If necessary, carefully wipe any excess toner powder from the positioning markers using a soft, lint-free cloth or tissue.
  4. While the top cover of the printer is still open, inspect the sensor that is used to locate the positioning markers on the belt. CAUTION! The photodeveloper is very sensitive to light. Cover the green metallic surface of the photodeveloper with a piece of paper while it is outside the printer.
    • Refer to this image, this image, and this image to identify the location of the sensor.
    • Verify that the sensor has not come loose from its housing and that it is not contaminated with excess toner powder. If necessary, clean the sensor with a soft, lint-free cloth or tissue.
  5. Re-install the photodeveloper cartridge and power the printer back on.
  6. If the error remains, it is likely that a service call will be necessary to resolve this issue. Please contact Lexmark Technical Support, having first obtained the serial number of your printer. NOTE: If practicable, attempt to order another photodeveloper and replace it first to avoid the inconvenience of a potentially unnecessary service call.
Jun 22, 2009 | Lexmark C510n Laser Printer
Red light stays on, but nothing moving after clearing paper jam
About the last post, I must also add that the main clue that led me to that conclusion, was the fact that, when I first turned the printer on, THE FAN BEGAN to rotate. Hence, I thought, all the other aspects were right, but somewhere there might be a mechanical "jamming" that stops either the fan or other part to move and obstacles the cylinders or gears from moving, hence sending the printer a signal of jamming. I had looked for the "messages" from the printer, and the diagnosis for our problem (red light in the online error, and green light in Toner Save) was that either there was no ink or no cartridge, no paper, or paper jamming (please post if there was other cause for this diagnosis). I discarded the other grounds, so the unique left was that the printer thought was that there was a paper jamming. This lead to the fix I described in my previous post.
Regards,
David López Salgado
Bogotá, Colombia
May 02, 2009 | Samsung ML 2010 Laser Printer
Service Error 5100
Somtimes in order to get the printer to reset properly you must turn it off, unplug the usb (or other data cable), unplug the power cord and wait a bit. (Canon says 10mins.!).
Then reconnect cables and turn it on.
This should reset an alternate orange/green light condition.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | Canon Pixma iP2600 Photo InkJet Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Samsung ML 1610 Laser Printer Logo
474 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
