Question about HP Officejet 4315 All-in-One Printer
No communication between computer and laptop
The other day I had a paper jam and later tried to print but the printer would not acknowledge the print job. I did the press the ok and cancel button as I plug the printer up and that did the test sheet and everything on that end a worked. Tried to print the page and no response.
  • 876 Answers
I don't know which Op system you have, but you will need to look in your printers folder or on control panel printers and faxes and click on your printer>then cancel all documents. You may need to do a simple reset which is to uplug the printer from the power source, open the door where you clear paper jams and give the paper roller a gentle push forward until it clicks. If neither of these options helps you, you may need to reinstall the printer drivers.
Posted on Aug 15, 2008
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
The printer doesn't print when you tell it to from the computer. When you mess with the buttons, then it will sometimes print a day later.
Its not a net work printer, they how you are connected this printer for all computers & laptops?. It might be connected to one system from there its shared..right. In this situation if any computer fired print command it has to reach the local computer where printer connected. If the local computer shut down, printer unable to print due to no print command.. or else if any net work related issue with in your systems you wont get prints.. Find out were you are stuck. If printer is printing well from the local system you cannot suspect the printer. Just you start from local system, then check in all systems. Pl get back to us for further remedies..best of luck..
Feb 04, 2012 | HP LaserJet 3050 All-In-One Printer
The printer says it is out of paper, even though it is loaded
clean your paper rollers in side printer and make sure spring on paper loader isn't sprung
Jul 27, 2009 | Dell Inkjet 720 Printer
Paper Jam
ya i too got the same trouble
then when i checked it was due to lack of ink in print catridge so u too check for it and switch it off and try later and cancel all prints
Jan 20, 2009 | HP DeskJet 3650 InkJet Printer
Paper jam
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";}@page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;}div.Section1 {page:Section1;}--> lets tryfew troubleshooting for paper Jam issue.
locateand slowly pull out the stuck paper, perform the following steps:
1. Turn off the printer.
2. Open the printer cover.
3. Locate the stuck paper.
4. Remove the paper.
5. Close the printer cover.
6. Power the printer back on.
Locateand Remove any obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure thekickstand (if there is one) is engaged.
2. Locate and remove any obstructions withinthe printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for anyobstructions.
6. Remove any visible obstructions.
7. Reinsert the paper.
Adjustthe Printer Paper Guides
Extendthe front paper support on the printer.
Try aDifferent Piece of paper in the Printer
1. Take the top 10 sheets off of the **** ofpaper.
2. Verify that the remaining sheets of theream are not wrinkled or dirty.
3. Replace the remaining part of the ****back in the printer.
Reseatthe Dell Printer Power Adapter.
If yourprinter has a momentary loss of communication with your computer, it may benecessary to reset the printer to re-establish communication. You can reset aprinter by unplugging the printer power cord from the electrical outlet andfrom the back of the printer for 10 seconds then reattaching the cord at bothends.
Try aDifferent Type of Print Media
Manyimage quality and paper feed issues are caused by the type of print media beingused.
Try adifferent type of print media that is specifically made for this printer.
Whenthere is no different print media available, take out the top half of the stackand flip it over.
Tryholding the printer upside down and shake it moderately
Make sureyou remove all the cables from printer before performing it
Checkwith manufacturer if printer is still covered under warranty...
If yesthen get it replaced.....or else get a new printer
Oct 29, 2008 | Canon PIXMA iP1600 Printer
Printer will not print
I have the same problem nothing will print a need to print a fax report I need a confirmation.
Sep 02, 2008 | HP Officejet 4315v All-In-One InkJet...
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
