Question about Tally T6218 Matrix Printer
Sotutions If the printre is given u shuttle fault in tally 6306 what do u think
    New Friend:
  • 114 Answers
There is no shuttle in 6306 printer . so the problem will never come.
Posted on Jan 30, 2009
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before.
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before. os window xp
Aug 29, 2013 | Office Equipment & Supplies
Shuttle solenoid T6306 Printer
Hi we provide Service support for all type of Line printers.
Oct 20, 2012 | Tally 6306 Matrix Printer
Faulty Hammer voltage-2 earr
There is most likely a fault with one of the hammer coils, this would need investigating, other possible causes;Faulty / damaged ribbon cableFaulty main boardUpdate firmware, the error should change to a more meaningful error with later firmware
Dec 16, 2011 | Tally 6306 Matrix Printer
Paper out display in control pannel,not give test printr
prse line feed(lf) key and enter key for few second,on display gives tech access on
after that press ff key and enter key,display shows fault override on.
use your printer.......
Sep 24, 2011 | Tally 6306 Matrix Printer
I GOT PROBLEM IN TALLY 6303.ERROR CODE IS HAMMER VOLTAGE 1 FAULT, CAN U HELP ME WHUCH IC OR CHIP FAULTY
It could be the problem with your Hammer bank/ Hammer bank cable or MLC, Some cases dusty hammer bank .
Sep 25, 2010 | Tally 6306 Matrix Printer
HOW TO REMUV TALLY T6306 SHULELL ASSY
Do not do that! You won't be able to adjust this correctly after you installed the shuttle system again. This part can't replaced in the field. Only in the manufacturers repair center with special tools. Btw, it is very unlikely that the Shuttle system fails at this type of printer.
Aug 17, 2010 | Tally 6306 Matrix Printer
Fault hammer voltage 1 problem facing in lipi 6306 line printer pls give the suggestion to solve this gopi
it is good.
We are always here to serve your needs and provide quality service. Ourproducts range include replacement computer batteries for most majorlaptop brands, including Dell, Apple, Compaq/HP, IBM/Lenovo, Fujitsu,Gateway, Sony and Toshiba. <a href=http://www.bestlaptopbattery.co.uk>laptop batteries</a>
Apr 15, 2010 | Tally 6306 Matrix Printer
Shuttle fault
If the printer detects the shuttle moving at the incorrect frequency, it shuts down the shuttle and attempts to restart it.
If the shuttle still operates incorrectly after three consecutive attempts, the Printer goes Offline, and the Shuttle Fault message is displayed.
Press the Clear button, then put the printer back Online. If this doesn’t work, turn the power switch off, then back on again.
If the error is still seen after performing the above actions, check there are no paper jams , labels etc or ribbon jams that may prevent the shuttle moving correctly. Also check the Patten gap to make sure it is not closed too much.
Then you may need to change shuttle components
Dec 04, 2009 | TallyGenicom 6306 Matrix Printer
My Tally T6218 gives the following error message shuttle fault
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
Nov 30, 2008 | Tally T6218 Matrix Printer
Lipi 6306 Line printer
i want to knwon the which operating system supports the lipi tally genicom line printer model 6306
Oct 16, 2008 | Office Equipment & Supplies
Tally T6218 Matrix Printer Logo
229 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
