Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Not printing We just purchessed this printer last year with a new computer. It has started to making a noise when it is turned on and when you hit start to make a copy it makes the noise as if it is printing but it does not print. I do not think the light is moving, it seems to be stuck in one area. However I did get a copy of the Diagnostic Sheet which shows 5 errors. Error Code 3501 Error Code 6203 Error Code 6203 Error Code 3501 Error Code 3501 I don't know if this is helpful in your trouble shooting. I 'm not sure where I go from here. Thank you in advance for any help you can give me. Marilyn
  • 1 more comment
  • Anonymous Jul 31, 2008
    When I try to make a copy it is making this grinding noise. Then the error code 6203 shows up. It prints pictures just fine. I'm not sure what this code means.
  • ethanlittlem Aug 11, 2008
    my printer is not working, it only says it's printing onthe control pannel, but not at all doing so, also when copying, it'll do it but very very light
  • Matt D May 11, 2010
    I can definately help you with this issue but I just need a tiny bit more information.
    1. What are the dates from the Diagnostic sheet?
    2. Do copies come out ok or are they black, or just blank?
    3. What is the noise like, beep or grinding or something else?
    4. When you do a scan, open the lid and watch the light. Does the light move or does it stay like you thought originally?
Trying to connect printer to lap do not have the disk i have toshiba
laptop and kodak easy share 5300
Posted on Aug 10, 2008
    Problem Solver:
  • 8 Answers
Try to press and hold the copy and cancel button at the same time. It should take up a pice of paper and spit it out blank. then try to print again. if problems persist call the 1 800 235 6325 kodak support hotline
Posted on Aug 09, 2008
HP LaserJet P2015dn Printer won't print from vista computer. If i stop and start the spooler it prints. I have another printer and I don't have to stop & start the spooler for it to print
Try to Create a new account using your Administrator account and then try to print from there. If it works perfect Otherwise ..!
1. Start, Run and type cmd hit enter
2. Type msiexec /unregister hit space and press Enter
3. Type msiexec /regserver (note the space) and press Enter
Now restart the computer. And Restart the Print spooler service.
Click on start--> run--> type cmd hit enter-->
on the black window --> type net stop spooler hit enter--> again type net start spooler hit enter.
Each time it should say successfull stop or start.
Now try to print. If still does not work.
Check the port of the printer. ( start-->run--> type control printers hit enter-->right click on HP LaserJet P2015dn Printer series--> choose properties--> on the top--> choose the TAB--> Port-->now check the port ---> it should USB001 port if its a cable connection--> if wireless it should show HP ip address .
Make sure this is right and then try printing. It should work .
Let me know if it works.
May 07, 2010 | HP LaserJet P2015dn Printer
Lexmark 1270 All In One Printer, Scanner, Fax
I suspect it is because the print buffer in the printer is not being flushed properly and the document is sort of getting hung in limbo between the computer and printer.
the only way to clear cue is either re-start, disconnect the printer from the computer, or turn the printer off. Sometimes you may need to unplug it as well.
Mar 03, 2008 | Lexmark Color JetPrinter Z42 InkJet
While printing there is a noise
Maybe go to a local store and try a display model of the same printer and see if it makes identical sound. If it doesn't make the same, contact whoever you bought from to see about warranty or refund. Can also contact HP customer service for advice.
Sep 16, 2009 | HP LaserJet 5200tn Printer
I have a Samsung ML-2010 mono laser not printing
Yes, you can make a self print test from the printer even if the printer is not connected to the computer. This means that the unit is in good working condition. Possibly your printer doesn't communicate with your computer. try this, hit start key>control panel>fax and printers>select your printer>right click to properties>click ports tab>check if the port is matched to the port you are using.also, make sure it is your default printer.
Jul 08, 2009 | Samsung ML-2510 Laser Printer
Problems printing 4x6 with MP600
You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer will not print
Create a New User Profile like Test Account and try printing from that account and check if its printing from there..
How to Create a New User Account ?
XP
Start>Control Panel>User Accounts>Create New Account it shoul be admin...
Vista
Start>Type User Accounts in Search>Click User Accounts>Manage Another Account Create New Account..
If its able to print fine in new account then that means the profile of your old account is corrupted..If its doing the same thing in new account also ..Reinstall the Printer driver in the following Method..
Disconnect the Printer
1.Click>Start>Control Panel>Printers and Faxes and delete the The Printer that you are reinstalling the driver for delete all if there are more than 1 printer of the same.
2.Go to Control Panel>Add/Remove Programs> Uninstall the Lexmark related Programs
3.Restart the computer
4.Start > Run > Type in "cmd"
5.now you will have command prompt Type this and hit enter "net stop spooler"
6.Click>Start>Run Type in "C:\WINDOWS\system32\spool\drivers" Hit Enter
7.You will have the following folder open rename the W32X86 folder to W32X86.OLD
8.Restart the computer
9.Insert the Lexmark CD and start installing the software Note : Connect the Printer only when the installation is prompted to connect..
This should defnitely take care of your problem..
Note if you are using vista try this first
Start type msconfig open that go to tools tab and disable UAC and restart and check..
Jan 28, 2009 | Lexmark X1270 All-In-One InkJet Printer
Tractor sounding noise when I turn printer on
This has to be fixed by a technician. The feed gears probably need replacing or another gear could be suspect in your copier.
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Printer not receiving jobs from computers in office..HELP!
what type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
Feb 15, 2008 | Kyocera Mita KM-2050 Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
294 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
