Question about EliteGroup 661FX-M7 (661FXM7V11) Motherboard
Where could i find BIOS Jumper for mother elitegroup 661fx-m7?
Dear HotHwak,
Thank you for assistance for finding soluition to my motherboard EliteGroup 661fx-m7 rev.1.1 problem.
You mentioned in your last mail that i should check if the Bios jumper in installed in right way. please can you explain whaere to find the Bios jumper on the motherboard EliteGroup 661fx-m7 rev.1.1?
Hope to receive your favourable reply soon!
Best regards,
MATTOTECH
  • Anonymous Mar 07, 2009
    President:
  • 2,351 Answers
Hi MATTOTECH, when you receive a reply from a tech or wish to continue the post with the same tech do this. When you log into Fixya go to you're profile, listed there will be you're question. Open that question & continue / post more question (s). When you create another question like above, you will not get the same tech.
MATTOTECH if you do not have you're user manual for the ECS 661FX-M7 (V1.1) motherboard. You can download it from this link. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=476&DetailName=Manual&MenuID=44&LanID=0
Create a folder on you're desktop & give it a name. Download the manual, file name 661FX-M7.zip into the folder. Uncompress the file within the same folder. You will need Adobe PDF reader to view the pdf manual. If you do not have Adobe reader you can download it for free here. http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Go to page 4 which will show you a picture of the board. Each item is numbered. Page 5 will describe each number.
Number 6 is the bios jumper. Than go to page 9. This will show you how to set the jumper to clear the bios/cmos. (Leave it in the clear position for 15 seconds), than move the jumper back to pins 2 & 3, its normal position.
EliteGroup 661FX-M7 (V1.1) main web site
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=476&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Mike
Posted on Jul 27, 2008
I have 661FX-M7 motherboard. Will it use a 64 bit processor?
Visit the below link for available processors ur motherboard can support.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=476&DetailName=Feature&MenuID=1&LanID=0
Vote if found useful so that its easy for other to find the same content.
Jun 09, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
Driver sound card
Hello. You can download the sound card driver for your EliteGroup 661FX-M7 Motherboard by accesing this website: http://driverscollection.com/?file_cid=42171620436b85b5f3172dd905e
The driver above is available for the following operating systems:
Windows XP
Windows XP 64-bit
Windows 2000
Windows ME
Windows 98
Enter the code shown then download the driver to your computer. Run the program and install it properly!
If you have any other questions, please leave a reply!
Thank you for using FixYa.
May 28, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
Does a core 2 duo processor work on an ecs 661FX-M7 motherboard?
Your motherboard was set up for a pentium 4 or celeron d only and neither are dual cores, So the short answer is no,'
But there are many 3+ ghz celeron d's that are less then 50 online
Oct 06, 2010 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
Where to i download manuels for motherboard 661fx-m7
http://www.driver-central.com/661FX-M7_BIOS-8735-e7b0-driver.html
May 15, 2010 | EliteGroup 661FX-M7 (661FXM7V11)...
No display on monotor and not booting properly
This mother board requires an additional 12 volt 4 pin supply connection.
This connection is a reference voltage for your video and if the connection is not made or the supply is not supplying the correct voltage, you will experience the symptoms you have.
Either way, you should disconnect the board from the supply and check all caps for possible crowning or leakage.
While disconnected, the supply is called a switching supply and may reset.
Remove your memory, CPU and CMOS battery.
In the time you have the board out for inspection, you should have cleared any BIOS and CMOS setting being held in memory.
Blow the board out and re-install all you removed units, trying the motherboard 1 component at a time.
Good luck, hope it was just a simple reset.
Nov 24, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Acer 661fx-m7 1.2a
Download DRIVER AGENT it is FRE and will do it.
Jan 18, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Motherboard
Check the power supply may be faulty
check to see if cpu is overheating > go to bios and hardware monitoring
should hover around 45-55c stock amd heatsink
Aug 28, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Computer starting up and the processor turning too fast then the pc shot down by self
Are you hearing any beeping sounds and also please check your power supply by removing the supply 20-24 pin cable and refresh the bios - see the bios jumper is inserted in normal position
Thanks Hothawk
Jul 24, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
EliteGroup 661FX-M7 (661FXM7V11) Motherboard Logo
1,054 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
