Question about HP LaserJet 3055 All-In-One Printer
Can I connect my HP 3055 to magicjack for faxing
I want to connect my fax to a voip will this work. If I can't do this please give suggestion short of phone line or efax.
  • 162 Answers
Sure you shouldn't have any trouble doing that. I'd say a magicjack.com would be cheaper than voip since it's 20 a year.
Posted on Aug 12, 2008
Fax machine does not receive FAX
The problem is that the codecs used by VoIP IADs are designed to compress voice, not the analog signals sent and received by modems.
In a VoIP Internet world, voice is first converted into packets and then they are sent over the connections that make up our our vast Internet. They may take slightly different times to arrive at their destination. In doing so some packets may be discarded, but the end result is that the receiving VoIP device has enough packets to make a clear and understandable conversation.
We suggest these settings on a fax machine for faxing over VoIP; slowing the transmission rate down and allowing the machine to continue receiving the transmission even though a few bits of data were lost, then faxing over VoIP can become more consistent. Our suggestions in many cases can resolve issues that prevent faxing over a VoIP connection, but not in all cases. If after trying and making all the VoIP fax changes we suggest you still cannot fax over your connection then try a Internet Fax service.
Aug 10, 2011 | HP Office Equipment & Supplies
My problem is that I have just purchased Vonage as a VOIP phone line. I have a HP LaserJet 3055 printer/fax and I am trying to send faxes but it does not work. I was instructed to lower the baud rate,...
Configuring the V.34 setting to Disable (Enable is the default setting) to lower the speed.
Voice over IP (VoIP) services provide normal telephone service, including long distance service through a broadband Internet connection. These services use packets to break up the voice signal on a telephone line and transmit it digitally to the receiver, where the packets are reassembled. The VoIP services are often not compatible with fax machines.
If you continue to have problems faxing, contact your VoIP provider. Because the installation process varies, the VoIP service provider will have to assist in installing the all-in-one fax component.
Although a fax might work on a VoIP network, it can fail when the following events occur:
• Internet traffic becomes heavy and packets are lost.
• Latency (the time it takes for a packet to travel from its point of origin to its point of destination) becomes excessive.
Feb 15, 2011 | HP LaserJet 3055 All-In-One Printer
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
Fax on g85 w/magicjack (voip)
No, ALL fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line or Magic Jack.
Nov 05, 2009 | Office Equipment & Supplies
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Comm error 232 & no fax detected when receiving
Sam here. Anyone have a solution?? We use a voip setup for phones. Wondering if its related. We have signal converter boxes installed.
Oct 21, 2008 | HP LaserJet 3055 All-In-One Printer
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet 3055 All-In-One Printer Logo
246 people viewed this question
Seeker5211
Seeker5211
