Question about Nikon Cameras
I go into setup on the camera to turn on the shutter sound how-ever when i switch back to the men u it doesnt show that i have turned it on, and when taking a picture it doesnt work. Is there another option i have to turn on the make the shutter sound work when taking a picture?
You Can not have Continuous Shot, Or BBC on if you choose to have a shutter sound. Both must be shut off in order to achieve shutter sound.
Posted on Jul 28, 2008
My canon eos 550d shows error 80
ERR 80: SHUTTER
DESCRIPTION: This error occurs in the following conditions.
When the CAMERA self-check system detects that the shutter has not been fully charged (ready to shoot).
When the CAMERA self-check system detects that the shutter operation sequence has not been completed correctly.
When the built-in flash cannot be recharged after the E-TTL preflash but before the main exposure.
REMEDIAL MEASURE: Try clearing the error by turning the main power switch OFF and then back ON.
Feb 05, 2013 | Canon EOS 550D Rebel T2i Digital Camera
How to turn off the sound of the camera
That will be listed under MENU and possibly SETUP and scroll down and turn it off.
Jan 20, 2013 | Lenovo Cameras
My new 2month old..d300s..my if Switch Off it shows On..LCD goes Blank..no live view..on top LCD..doesnt show the details of memory card..like how many photos to be clicked..CF...PC doesnt ditect..etc.....
Hello. Turn it on and then go into the menu and find the reset function. Reset it. What this means is a reset to factory settings.
If that does not solve the problem return the camera while it is still under warranty. Joe
kindly rate my answer as 4 thumbs up. Thank you.
Oct 02, 2010 | Nikon D300s Body only Digital Camera
My shutter will not close when turned off but when turn on it goes in and out
sensors around your shutter are not functioning properly... so they need to be repaired....
Feb 22, 2010 | Olympus FE-190 Digital Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
$100 is hardly expensive, and at that cost it would be cheaper to replace it than have it repaired. In future, keep it on the neck strap.
Mar 15, 2017 | Cameras
Shutter
try this:
1.turn on yer unit
2.press the menu button(if it gives you the "turn power off and on again message just switch to play mode or preview mode and access the menu from there.)
3.select setup(the option with the toolbox icon)
4.select setup 1 (not camera 1 ayt?)
5.select initialize and select OK for every prompt.
you\'ll know if you\'ve sucessfully initialized the camera if it will ask you to set the date and time.
if this does not work.... i guess it would be better to have th unit checked by an authorized serivicer.
maimai alovera
avaya ****
Jan 13, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Cameras Logo
104 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
