Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Replacement of filter cartridge for water/ice
We replaced the new fiklter cartridge. Turned the ice maker back on (at the switch in top of freezer unit)-- nothing working here. No ice. No sounds at all. freezer ias cokld and freezing.
  • 126 Answers
I ASSUME YOU ARE GETTING WATER.YOU NEED TO CHECK THE WATER VALVE IF ITS WORKING THAT COULD BE YOUR PROBLEM.GOODLUCK.MOHAMED
Posted on Sep 17, 2008
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Icemaker has always been slow. It produces ice, just a couple or 3 times a day. We have to keep our old fridge running just to get enough ice... Cubes are full size, freezer is 0 degrees, not much...
The main reason behind an icemaker to make ice slow is the freezer temperature. It needs to be below 10 degrees. Also check the water inlet valve. Water is controlled by a timer and if its obstructed or slow filling, it will not make ice. You could also have a bad motor, defrost heater, or sensor. If these items fail, it usually won't make any ice. Check to be sure the electric plug from the ice maker is plugged in and check the water flow. However if it is filling up with water or if it just has a small amount in the cube maker. If it's making some ice, it's probably not a defrost problem. Check the voltage to the fill valve. Also replace the freezer's water filter, as clogged filters block water flow. Set the ice maker arm to "Off," and then twist the hanging filter cup counterclockwise to remove it. Rinse the cup under running water and discard the old filter cartridge inside. Slide a new filter cartridge into the cup and reinstall the cup assembly in the freezer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 27, 2011 | Kitchen Ranges
I have a whirlpool refridgerator with ice maker, freezer floods.
in the freezer section there is drain hole and you can see it if you take the back wall of the freezer (the inside wall) and you might just need to clean it all the way to the compressor drain pan.
Dec 29, 2009 | Refrigerators
Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice. Someone said it has a temp sensor and must be 10 deg b4 making...
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
Nov 02, 2009 | Whirlpool GS6NBEXR Side by Side...
The water dispenser is working fine, but there is not water going to the ice maker. The ice maker is turned on. I have removed the filter and put in the bypass plug. Any suggestions?
Switch the conectors going to the inlet valve.  Then open the freezer door, hold the switch to make the freezer think its closed and push the water button.  If water comes out by the ice maker then the valve is good and your ice maker needs to be replaced. If no water comes out the inlet valve needs to be replaced
Oct 25, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore freezer on the bottom. Ice-maker switch is turned on but no ice is being made?
Check your incoming water line for kinks. Make sure the water valve is turned on.
Replace the water filter.
Check inside the freezer and make sure the ice maker power cord is plugged in.
Mar 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
