I have a GE Dehumidifier, Model # AHK40LKG1, Serial # AM166016. Thus far we have used the bucket to empty it. We now want to use the hose attachment to empty it. I find that I have the clear plastic tube to be inserted in the back and the screws to secure the nozzle but I am missing the nozzle which goes onto the tube and is secured to the back. a hose is supposed to be screwed onto it to drain the water. I called your parts ordering department but they could not see the part on the diagram, so said that I should go on line and look for the part number myself. I cannot find where to look. Could you tell me the part number?
Comments:
Oct 29, 2008
- Excellent suggestion! I just ordered the part # from PARTSTORE.COM FOR $16.95 + Shipping. Not concerned with "cheaper" (within reason) as long as I can use the machine as I want. Problem seemed to be that GE did not include this accessory or optional part in the schematics for the Model so no one could see it to order the part number. NB: the Official description is "Drain Tap". We will see if it is the correct part in 3-5 days.
Thanks again, Jas.
I have same problem (ie, missing this drain nozzle). From my searching, the GE part number is : WK09X10006.
Found it on : http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
searching for 'drain nozzle'.
My searching (so far) is finding a couple places online to purchase this, but at $14-$15. Still looking for a better (ie, cheaper!) option.
Hope this helps.
The fins and coil in the back of the dehumidified freeze up. Iused a brush and removed a lot of...
(More)
The fins and coil in the back of the dehumidified freeze up. Iused a brush and removed a lot of lint. The pan under this unit has a lot of lint and grit/
after 10 to 15 minutes of operation the coils begin to freeze at the bottom and progress to the...
(More)
after 10 to 15 minutes of operation the coils begin to freeze at the bottom and progress to the whole coil pack. I've cleaned the coils and the fan is operating properly. One expert suggested I change the humidistat which I did. 50.00 later and it still freezes up. If the coils are freezing how could low freon be a possibility? Could it be the thermostat? HELP yours truly Paul k.
I Just bought a dehumidifier and it did not come with instructions. Every time I turn it on the fan...
(More)
I Just bought a dehumidifier and it did not come with instructions. Every time I turn it on the fan shuts down after a couple of minutes. What could be the problem?
