Question about Directv Universal Remote
I enter my code... it blinks twice to show acceptance of code... but then does not work
I bought a replacement remote, held the mute and select down as it says in the instructions, it blinked twice... I then entered by 5 digit code... it blinked twice again... as the directions said it would. Then, when I hit power to make it work - nothing happens. Am I doing something wrong or missing a step?
IF the codes in the book do not work go on line for new codes www. directv.com
the book I got with my remote has copyright date of 2006
Posted on Jan 07, 2009
My directv remote will no longer work t v re programmed it for another tv and works fine the orgial remote will not work either funny thing this happened today after replacing old batteries
10 Steps to Program Your Directv Remote
1. Turn on television.
2. Locate the switch at the top of your remote that allows you to toggle between receiver, auxilary, and TV modes. Slide switch over to"TV".
3. Hold down MUTE and SELECT until a small green light at the top of the switch blinks twice.
4. Enter code 9911.
5. Press and release the CHANNEL UP button repeatedly until television turns off.
6. When TV turns off, press SELECT.
7. Next, press the power button. This should turn the TV back on.
8. With television on, press and hold down MUTE and SELECT again until the small light blinks twice (same as in step 3).
9. Entercode 960.
10. Slide switch back over to "DTV". Your remote is now ready to use!
Nov 01, 2010 | Westinghouse SK-32H240S Television
I lost the manual and i dont know how to program it please help its an older direct tv remote?
4. Enter code 9911.
9. Entercode 960.
Jul 01, 2010 | Philips DIRECTV R15
Rca remote to set crt tvofsony
These are the steps and codes for yout to set your RCA remote to your Sony TV.
1. Set the "Mode Switch" to TV.
2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
3. Enter the 5 digit Code.
Codes: 10000 10834 11100
But then if it still doesn't work, you can still try doing these steps.
1.Set the "Mode Switch" to the desired mode such as TV for a Television.
3. Enter the code "991" followed by the "device number", in your case you are programming it to a sony tv so use 1.
4. You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
5.You can try out each code by pressing one or more function keys such as power, volume or digit keys.
6. When you've found the setup code that works for your device, press the "Select" key.
Jun 13, 2010 | RCA DIRECTV Satellite Remote Control
I am unable to set up my directv remote to shut off and on & volume up and down on TV
hi,
make sure slider on the top is all the way over to the left then..
hit menu down arrow to parental, favs, setup hit select down arrow to system setup hit select down arrow to remote down arrow to tv choose brand in right list find code
MOVE SLIDER ON TOP ALL THE WAY TO THE RIGHT POINT THE REMOTE AT YOURSELF HOLD DOWN SELECT AND MUTE UNTILL LIGHT BLINKS TWICE
ENTER CODE
LIGHT WILL BLINK TWICE AGAIN
TRY THE BUTTONS
IF IT DOESENT WORK TRY A DIFFERENT CODE
OR GOOGLE DIRECTV CODES
NAVIGATING THE DIRECTV WEBSITE FOR CODES IS NEARLY IMPOSSIBLE. GOOGLE CODES.
JM
Jan 24, 2010 | Televison & Video
Code for Sky+ remote to work with Toshiba TV AV635DB
Hi there. I have just bought the same television today and I have just found that the remote code 0156 does actually work. The mistake i initially made was not pressing the TV BUTTON after I had held in the SELECT and RED Buttons together, making the light blink twice. So here's what I did:
1. Press the TV button
2. Hold in the Select and Red Button until the red light flashes twice
3. Press the TV button again
4. Enter the code 0156 (The Red light will blink Twice again)
5. Test the controller - Try to change the volume
6. If it works, press SELECT one last time to save the settings.
Hope this helps.
apnit
Jan 04, 2010 | Televison & Video
I'm looking for the remote code to program a directv remote to a Polariod model ttm-2410 tv. Know any?
direct tv gives this code 11641
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • more possible codes 11326 11991 10765 12002 11992
    still more
    11523 11276 11498 11327 11328
    11314 11262 11962 10865 11316
    11286 11341 10178 10835*
    Codeslisted with an asterisk (*) are possible alternate codes for yourdevice. These alternate codes should operate the primary functions ofyour device in most cases (Power, Volume Up/Down, Mute).
    There is no other setup code indicated for your product
    that links to the model number you entered.
    Youmay still find a setup code that works for your device by steppingthrough the library codes in your remote. The following instructionswill help you do this. StepNSet
    • Set the "Mode Switch" to the desired mode such as TV for a Television.
    • Enter the code "991" followed by the "device number"
      1. for Televisions
      2. for "AUX 1" devices - VCRs or DVDs
      3. for "AUX 2" devices - Audio
    • You can step through the setup codes for this mode by pressing the"Channel Up" key to go forward through the codes or pressing the"Channel Down" key to go back to the previous codes.
    • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
    • When you've found the setup code that works for your device, press the "Select" key.
    This is all the information I could find, Poraroid does not offer a URC code.
    Hope this helps
    Please take the time to rate this solution
    Feb 01, 2009 | Televison & Video
    How do i key in code for digibox
    TO PROGRAM THE remote USING THE 3 DIGIT CODE:
    1. Turn on the TV receiver
    2. Press TV on the Sky Remote Control
    3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
    4. Enter three digit code from list for the receiver (early versions now flash twice).
    5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
    6. Now press the STDBY button and test other functions.
    Repeat if necessary until a code is found that works most common functions.
    TO PROGRAM THE remote USING THE 4 DIGIT CODE:
    1. Turn your TV on.
    2. Press tv on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Press tv on your Sky remote control again.
    5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
    6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
    If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
    At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
    8. Press tv on your Sky remote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
    10. Key in the number of the channel on your TV that you use for watching satellite TV.
    11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
    If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
    Dec 19, 2008 | Computers & Internet
    Directv AV1 switch Volume Problem
    Did you try all the codes listed. Some work certain functions such as power but not volume. Did the installer leave a phone number where he could be reached other than directv toll free number? Did you receive the same remote as the original. Directv has two remote that are identical in appearance but one is rf capable and the other is infared. The RF remote has backlit keys and is compatible with just about any device.
    Aug 03, 2008 | Universal Remote Control DIRECTV Universal...
    Remote code for Sony Home Theater
    This works for ALL Sony Home Theater Systems
    Remote Code: 21232 (a Sony code for TV/VCRs).
    Then do the following:
    1. While still on AUX, press and hold SETUP again until the remote blinks twice
    2. Type 994
    3. Press and release SETUP
    4. Type 32975
    5. Press and release VOL+
    The remote should blink twice. That should reprogram the VOL+ to work with your Sony device. For each of the following function codes, follow the same steps and use the codes listed below:
    Vol+ = 32975
    Vol- = 31951
    Power = 32719
    Function = 44750
    Mute = 33743
    Oct 29, 2007 | Televison & Video
    Directv Universal Remote Logo
    163 people viewed this question
    Top Directv Televison & Video Experts
    john milligan
    rundiggity
    Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
