Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Wont heat dryer seemed to have stopped heating up...every once in awhile it will heat up. dryer is only two years old
  • 750 Answers
Huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Oct 06, 2008
Dryer is not drying igniter coming on but wont stay lit lites once in awhile
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 24, 2011 | Whirlpool Dryers
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Hi my dryer is only just over 1 year old so of course warrenty is up and it wont heat. it runs and circulates but no heat, my husband cleaned out the vent tube what else can we do?? it cant be major its...
it could be the heating element even though it is just over a year old, i have seen heating elements go out on 3 month old dryers, it also could be a thermostat the best thing to do is make sure it is getting the full 220 volts going to it, if it only has 110 volts the motor will run and have no heat and vise versa, then if that is good get to the heating element and look it over real good most of the time the heating coil will be broke into it wont look burnt just broke
May 04, 2011 | Amana Dryers
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | LG DLE2514 Electric Dryer
Dryer will light and heat for a minute or so then goes out and wont relight again until it sits a while-
check your vent going out through the wall and be sure its not stopped up
Apr 23, 2009 | Dryers
Gas dryer wont heat
Looks like the gas valve coils are failing. This usually begins to happen later in the cycle as the dryer has run for awhile. You will have to have the coils replaced.
http://tclaundryrepair.com/
Feb 25, 2009 | Amana ALG866SB Gas Dryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Dryer wont get hot in the am i try it it will wrk for one load then wont get hot same thing for 4 days now
I have a Whirlpool dryer with LP gas, 7 1/2 years old. It will fire up once or twice after started then the next time it is supposed to fire it will make a buzzing sound. No heat. It will not produce heat after this until it sits for awhile then the same thing, will fire once or twice then no more. I replaced the ignitor and this did not solve the problem although it did have a consistent firing for about 3 minutes immediately after I replaced the part. then it started buzzing again and would not fire anymore. The propane line doesn't appear to be the problem either since it will work initially. Also the gas water heater in the house works fine.
Sep 23, 2008 | Kenmore Dryers
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
