1. press * and # to enter a secret support menu. 2. Enter code 123 3. Press Right button until "System Config Menu". Press OK. 4. Hardware Failure Status. Press OK 5. Press OK to Clear. 6. Cancel 7. Press Right button to Ink Initialization Status. Press OK 8. Cancel and Cancel to the secret support main menu. 9. Press Right button until "Print Tests Menu". Press OK. 10. Nozzle Test. Press OK 11. Wait until the print test is finish. 12. Press Cancel and Candel until the error 0×00000000 appear and then power off. 13. Power On again. The error disappear.
You'll want to try and reset your printer, the steps are below.
Reset the product:
1.Without turning off the product, disconnect the USB cable from the rear of the product.
2.Remove the cartridges from the product.
3.Wait for the 'Insert Cartridges ' message to display on the control panel.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.Reconnect the USB cable to the rear of the product, and then try printing again.
Let me know and don't forget to vote on this solution :)
SOURCE: Error: OXc18a0201
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Testimonial: "Thanks for the great fix. The new look on my face was priceless. "
