Question about Vacuums
How do you put a new belt on heritage legend 2
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=832437
Generic problem for all Vacuums
How do you put a
Posted by boogerjrjr on July 25, 2008
How do you put a new belt on Kirby Heritage Legend II
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 25, 2008
The brush on my kirby won't turn
It may have something caught in the roller mechanism if not the belt that drives the roller may have broken or slipped off. If the problem is neither of these then the motor that drives the belt to drive the roller may have failed, Please take to an authorized service centre and have it repaired or replaced if it does not cost more than a new vacuum if it is going to cost more than a new vacuum then discard that machine and purchase a new one. I hope this helps.
Sep 13, 2012 | Kirby Heritage I and II, and Legend I and...
How do I put a belt on the carpet shampoing attachment on Kirby Heritage 11
This will require 2 phillips screwdrivers. Insert the screwdrivers into the screw heads and unscrew one side while holding the other so it will not turn. When the screw is out, tip the brush up and slide a new belt on.
Feb 03, 2011 | Kirby Heritage II Vacuum
How do you put on the attachment hose?
The Heritage II Legend...First you make sure that the machine is unplugged from any outlet,. Now, raise your height adjust to the highest level. Next you will need to turn your belt lifter on the front of the nozzel to the right as far as you can. Now flip the hinged light cover up, and turn the latch that holds down the head to the left. Your nozzle is now released. Now take the hose and roll it on to the bar from the front to the back, make sure it is aligned and then turn the latch to the right locking the hose, and you are ready to kirby it up! Hope this fixesya! Let me know, Thanks, Rene (the Vacuum Doctor)
Nov 13, 2009 | Kirby Heritage II Vacuum
Kirby Legend 2 Vaccum cleaner
Did you ever find a use and care book for this vacuum.  I have one I could scan for you.
Jun 27, 2008 | Kirby Heritage II Vacuum
Kirby Heritage 84
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=699518
Kirby Heritage 84
Posted by sixbrocks on Jun 23, 2008
I can't figure out how to get the belt engaged on my Kirby Heritage 84. There are very simple instructions on the front assembly; however, the belt doesn't engage with the rotor, and the beater bar does not spin. When I have the front twisting section on the "Belt On" setting, it seems as though it actually disengages the belt. I see no faults in any of the mechanical parts, but just can't get the belt to go on the rotor.
(I purchased this machine @ a garage sale on Saturday. It's in perfect condition.)
My vacuum cleaner is a Kirby 84 Legend.
Help! Jennifer
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check your owner’s manual but the Kirby has a dial on the front of the machine and you needs to dial the belt off of the fan pulley counter clock wise and to check to see if the Kirby bell housing will release @ the top so that you can remove the bell housing. If not then remove the bottom plate and take out the brushroll on one side and then slide the belt off of the brushroll. Then you can slide the new belt onto the brushroll to the center and then re-insert the Kirby brushroll with the screw heads facing downward then you can replace the bottom plate – then use the Kirby spoon or hook to dial the belt onto the fan pulley clock wise. Once that is done then plug in the Kirby and try to vacuum to see if the Kirby is picking up properly, if not repeat the process. If you have a question, feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
Cleveland, OH 44102
Go Ahead. Use Us.
Jun 23, 2008 | Kirby Heritage II Vacuum
Kirby heritage 2 sweeper
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
Feb 06, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
227 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
