Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frididaire FLSE72GCSA stackable washer dryer
I think my daughter overloaded the washer. The water solenoids open and water flows in but nothingelse works. No spin, no draining, no noise of switching units, no noise of belts sliping or flapping around, no nothing so I suspect the timer switch but need professional opinion.
    Novelist:
  • 116 Answers
It is possible that the belt has come off or the lid latch is no functioning.
First unplug the machine then remove the two screws from the front lower edge of the washer.
The front panel will lift up towards you at a 45 degree angle. The latches will release than the entire front panel can be place out of the way.
The lid latch can be seen on the underside of the top panel to the right, check that the wires are not loose.
You will see a large motor mounted upright near the base this should have the belt around the pulley to the bottom of the tub assembly. Check for obvious damage
Outside of this you will need a repairman for help.
Posted on Jul 28, 2008
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
My daughter's maytag lse 1000 series 10 stackable dryer runs but does not dry. Where should I begin because she does not have a manual?
When you say it runs, I presume it spins but doesn't get hot. There are 3 likely causes for this.
1. The heating element has blown
2. The thermal overload switch is open
3. There's a loose wire going to the heating element
Best wishes,
Graemevm
Apr 06, 2010 | Dryers
We have a stackable unit and whenever we have to unplug it, the dryer will not heat. Is there a reset button?
can you describe to me alittle more in detail what your doing and is it electric heat
Jun 01, 2009 | Frigidaire Dryers
Wont fill and agatate
sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Aug 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
734 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
