Question about HP L1940T 19" LCD Monitor
MONITOR HP L 1940 TFT
I Have a monitor HP L1940 TFT and if I switch this monitor on without a
line connection to the computer the monitor gives a good message that
there is no line connection !
If I conect the monitor to the computer the monitor displays an intermittent
picture goes on and off(This computer is tested with an other monitor and than it works oke)
If I keep the AUTO pushbutton pressed and held it on pressed the monitor
works oke and the picture is stable
As soon as I release the Auto Pb the monitor start flashing again
Do You have any Idee what can cause this trouble!
Many thanks in advance
Gerard Nieuwenhuijs
gerpa@hetnet.nl
  • 3 more comments
  • Anonymous Feb 01, 2009
    mine too except nothing happens when i push the auto button
  • Anonymous Feb 07, 2009
    1 sec picture after any push button, then dark.
    what's this`?
  • atoemchen Feb 07, 2009
    same problem: picture, for 1 sec, then dark. repeatable after off-on or auto button pushed.
  • mulberry28 Feb 20, 2009
    I have an HP 1940 monitor. when I start the computer the screen comes on briefly, a white box flashes in the middle of the screen, and then the monitor goes black. I brought it to a local repair place who told me the bulb inside has blown...is the bulb repairable or should i toss the moniotr and buy a new one any help on this would be grea thanks
  • mulberry28 May 11, 2010
    how do i fix that?
I jammed my auto button and the screen now stays on!
Posted on Jun 23, 2012
Your input selector switch is broken.
Thomas, Denmark
Posted on Sep 08, 2008
I manage a building, located in a suburb of Houston TX. We have had several HP 1940 monitors overheat and start smoking (about 10-15) over the last couple of years. The company who provides IT service,...
Well, hook up a voly meter that have a max an min logging then take a look over time.
also, use a UPS on your monitor with a surge protection this will avoid line problem. then you will be able to argu that your line is not the problem.
As for the monitor itself, I can not tell.
Jan 02, 2014 | HP Computers & Internet
OSD LOCKOUT Display on my Screen HP L1940 Silver Lcd
Release the menu button (check if anything is leaning on it), and press and hold the menu button again until the message disappears (app. 10 seconds). If this doesn´t work, the button may be stuck, or there´s a problem with the hardware.
Nov 02, 2010 | HP L1940 19" LCD Monitor
Can't log in using Windows 7
OSD LOCKOUT display on my screen
Hp L1940 Silver 19" Lcd
HP L1940 Silver 19" LCD Monitor Part #: PF803A8#ABA HP L1940 Silver 19" LCD Monitor Part #: PF803A8#ABA
Nov 02, 2010 | Microsoft Windows Live Messanger
Line across lcd screen
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer. let me know if this resolved ur issue.. regards, guru
May 03, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
Nothing comes up..after connecting it to my laptop
Try using the menu on the monitor
to change the input mode (much like changing the input channel on a tv).
also make sure that your pc display settings are set correctly.
Mar 04, 2010 | HP L1940T 19" LCD Monitor
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
Horz/vertical.
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
http://h10032.www1.hp.com/ctg/Manual/c00276671
specs.
https://support.hp.com/us-en/product/hp-l1940-lcd-flat-panel-monitor/427303/document/c00278650#AbT3
testing
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
Hi...there,
It's open from the front bezel of the screen.. Place a piece of cloth or fiber cloth over the screen and carefully lifted up the bezel... do the same from other angles...
Dec 16, 2008 | HP L1940 19" LCD Monitor
TFT screen not working
hi
clean your vga ,fix it in your agp slot also remove dust from it .
reconnect all cable to board.also clen processor case.
clear your bios.
take away cmos cell for 15 minutes.
Mar 24, 2008 | MSI FX5200-T128 (128 MB) Graphic Card
Monitor turns off automatically..
It's possible that the ACPI (Advanced Configuration and Power Management Interface) is not enabled in the bios. To access the bios either press F2 or DEL, depending on the motherboard(usually tells you on the initial boot screen), then look for a line that reads 'Power Management Setup' or similair and press ENTER. When into the menu check to see if ACPI is reading enabled, if not press the right arrow on your keyboard then either press PAGE UP or PAGE DOWN or + or - on the keyboard. Press 'ESC' then it will ask if you if you want to save changes, press'Y'. That should sort it.
Oct 20, 2006 | Mitsubishi Diamond Pro 91TXM 21" CRT...
HP L1940T 19" LCD Monitor Logo
1,312 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
