Question about Maytag MFC2061HES Stainless Steel French Door Refrigerator
Water dispenser after changing filter at night; it worked, but tasted odd. Next morning it did NOT work...and still doesn't.
I just waited a couple of days without touching it. This afternoon, I attempted to use it with the filter cap on and it worked. I then emptied out two large glasses of water and proceeded to replace the new filter. It IS WORKING!
Posted on Jul 27, 2008
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Nov 27, 2007 | Refrigerators
A refrigerator without a water filter the water dispenser will not will not work am i right with that question?
Hi, W/D here.
The dispenser will actually work without a filter. I can remove my filter, and put on the temporary seal cap, and I get water!
Older versions of refrigerators were connected to water supplies without filters. What happened was that the water might taste "funny", or be discolored, but mostly, unfiltered water tended to kill ice makers. Nowadays, most refrigerators come with expensive filters. Lots of crafty folks put an in-line filter before the refrigerator to make their expensive filter last longer. The water tastes better too!
Best regards, --W/D--
Please feel free to rate this solution so that we may continue to help others. Thanks.
Feb 20, 2011 | Refrigerators
Ice and water from dispenser tastes like plastic.
try putting an inline charcoal filter on the water inlet, if this does not work change the water resevoir inside the refrigerator
Oct 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid 14-Cup has plastic, chemical taste
Run 1/4 cup vingar with a pot of water. The coffee is not finishing its cycle and some remains in the works. You may have to do this several times. Washing the carafe with ice and salt by swirling it around a few times until it sparkels clean. Last thing for a good cup of coffee is filtered water which will keep the unit cleaner too. :)
Sep 18, 2009 | KitchenAid KCM400 Coffee Maker
Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Jun 23, 2009 | Refrigerators
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Jan 03, 2009 | Whirlpool GD2SHGX Refrigerator
Water problem
if the lines are plastic then it has to do with your water supply line. is the supply a saddle type valve in your basement and is it connected to a copper pipe or a galvanized steel pipe?
Apr 30, 2007 | Whirlpool GS5SHAXN Side by Side...
Maytag MFC2061HES Stainless Steel French Door Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
