Yamaha M-65 Stereo Power Amplifier This amplifier has protection circuitry to protect the speakers on initial power up indicated by the red LED on the front panel. The problem is, this protection remains on under all conditions. Is this a common fault? Any advice or help would be much appreciated.
  • martinolio Jul 25, 2008
    Tried unplugging power cable for five minutes. No joy.
    Speakers OK
    Blown component seems likely. Which one is the problem.
  • 19,396 Answers
Try first unplugging power cable for five minutes , see if it reset.
Posted on Jul 25, 2008
  • 2 more comments
  • Ginko
    Ginko Jul 25, 2008
    If it does not reset, the protection power circuit detects excessive current of power MOS FET
    output and protects against shorts at
    each end of the speaker cables, and a circuit that protects against
    internal over-heating.
    Check your speakers, if problem persist can be short in speakers. Possibly test different speakers.
    It can also be a blown component inside or overheating (probably faulty fan).
  • Ginko
    Ginko Jul 25, 2008
    Take a chance with speakers , if the protection indicator is lit, then the speaker protection security had been activated.
    Often this can be reset turning unit ON and OFF or unplugging power.
    If it does not clear it means there is a real problem, either with the speakers or a fault in the unit itself.
    It must be tested with replacement speakers, can be a short on one fo the speakers.
    The protection circuitry can start also if there is a problem inside unit, in this case must be taken apart by a technician and tested.
  • Ginko
    Ginko Jul 25, 2008
    Well, if you go randomly you start testing from finals, check amp fuses on board etc. If you want to do it yourself buy the service manual.
    You will need the schematics in the manual.
    It has got also service procedures and troubleshooting diagrams for identifying the fault in a more rational way on the specific models.
  • Ginko
    Ginko Jul 25, 2008
    Here is more people with same trouble Yamaha M-65 in protection mode , but no solution given, apart taking the Amp for repairs.
Standby indicator flashes
When the "Protection" indicator comes up the display panel of my receiver or the On/Standby LED is flashing, does that mean my receiver needs to be repaired?
The "Protection" light comes on when the receiver's current sensing and thermal monitors detect some unusual operating condition that, if left unchecked, might damage the amplifier. This can happen if there's a dead short in a speaker wire or if you're using very low impedance loudspeakers at high volume for an extended length of time. On older model AVRs you may see the word "Protect" on the receiver's display. More current models will indicate a flashing red light on the Standby LED when a Protection circuit trips
n thermal cases, the circuitry will automatically reset after a few minutes of cool down and the Protection indicator will go out and normal operation will resume. If the protection light came on due to a speaker wire short, low impedance condition or a bad speaker, the receiver's power will need to be turned off to reset it. Before turning the power back on, all speaker wire connections should be checked for their integrity at the receiver side and at the speaker side. If the protection light goes on immediately after you turn on the receiver, disconnect the speaker wires at the receiver side and retest. If the receiver's protection light goes off, then there would still seem to be a problem with one channel's speaker wires or speakers. Connecting them one by one and retesting should allow you to find the problem speaker or connection.
If after checking all your connections, the Protection indicator stays lit, you may need to "initialize the microprocessor (see the FAQ on that topic) or take your receiver to an authorized repair center for a diagnostic. The "Initialization of the Microprocessor" or "reset" procedure can be found in your owner's manual on current model AVR product. Please note, this will erase all setup configurations in the system and require the system to be setup again. You may want to mark down the settings before resetting your receiver to aid in the setup process. If you had an installer setup your system, you can contact them for assistance and any associated costs that may apply to setup the receiver again would be the responsibility of the owner.
Jul 17, 2016 | Sony DAV-FR1 System
Just bought laney rb9 bass amp, the limiter defeater LED doesnt light up when switch is in or out. how do i know if this is working or not?
Best to leave the limiter on unless you want to blow the amp and require repairs. Limiters protect the amp and also sometimes the speakers. The limiters reduce the gain when the amp reaches the maximum swing. If the gain were not reduced the amp would "flattop" which results in the circuitry saturating and massive distortion and if this condition is sustained, components can overheat or short out requiring repair. The LED MAY be just an indicator of clipping rather than an indicator of on/off. I downloaded the manual and what I have just said is CORRECT. The LED is a clipping indicator.
There is a caution regarding this amp and the sequence to turn power on. This amp does NOT have good speaker protection and you have to have the gain control down when turning on. The limiter, if you leave it on, might help protect your speakers when powering on. Most good power amps have circuitry to disconnect the speakers while amplifier is powering up and becoming stable, this one does not, so heed the warning and for certain leave the limiter ON... It just might save the amp and your speakers.
Mar 02, 2011 | Laney RB9 300 Watt Bass Head
I have a s1500 samson amp I keep blowing speakers, what can I do to prevent this from happing again? The speakers that blown first was two 12'' yorkville 350 w impedance 8 ohm, the next speakers that blown...
Turn the volume down? Feed it cleaner source material?
http://s3.amazonaws.com/samsontech/related_docs/s1500_s2000_manual.pdf
You don't say under what conditions you're blowing them or if any of the informative indicators are warning you of impending doom. The Samson is capable of cooking just about any home speaker.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the
protection circuitry is activated and the speaker output is muted. If everything is
operating normally, you will hear an audible click at the conclusion of this brief
period, as the protection circuitry is deactivated and the S1500 / S2000 begins
delivering signal to connected speakers (at which point you'll hear a click). It is
normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the S1500 / S2000 will cause
the protection circuitry to be activated (and the Protection LED to go on)
whenever the operating temperature of the unit rises above a safe level. To
guard against this problem, make sure the S1500 / S2000 receives adequate
ventilation on all sides and that both the front and rear panels are unobstructed.
Severe overcurrent conditions: This occurs whenever the signal being input to
the S1500 / S2000 rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and
ground signals being output by the S1500 / S2000 short one another.
Output impedance drops below 2 ohms: This can occur if the S1500 / S2000
is connected to inappropriate speaker systems (see the "Setting Up and Using
Your S1500 / S2000" section on page 5 in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an
internal failure.
In general, any time the Protection LED lights up (other than during the
approximately five seconds following initial power-up), there is reason to be
concerned. If this occurs, turn the S1500 / S2000 off immediately and carefully
check all wiring and external devices in order to locate and correct the condition
that caused the LED to light up in the first place.
For further assistance, contact your local Samson dealer. If purchased in the
United States, you can call Samson Technical Support (1-800-372-6766)
between 9 AM and 5 PM EST.
Feb 07, 2011 | Crown XTi 2000 2-Channel Amplifier
No sound coming with protection light on
It's either overheated or you may have faulty speaker wiring or a shorted speaker. These directions come from a Samson servo 120a but the theory is the same.
Initial power-up: For approximately five seconds after initial power-up, the relay
speaker connection circuitry is deactivated and the speaker output is muted. If everything is operating normally, you will hear an audible click at the conclusion of this brief period, as the circuitry is activated and the Servo 120a begins delivering signal to connected speakers (at which point the Speaker LED will light if the Speaker on/off switch is in its "in" position). It is normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the Servo 120a will cause the relay speaker connection circuitry to be activated (and the Protection LED to go on) whenever the operating temperature of the unit rises above a safe level. To guard against this problem, make sure the Servo 120a receives adequate ventilation on all sides ; in extreme environmental conditions, you may also
want to consider the use of cooling fans.
Severe overcurrent conditions: This occurs whenever the signal being output
from the Servo 120a rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and ground signals being output by the Servo 120a short to one another.
Output impedance drops below 2 ohms: This can occur if the Servo 120a is connected to inappropriate speaker systems (see the "Setting Up and Using the Servo 120a" section in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an internal failure. In general, any time the Protection LED lights up (other than during the approximately five seconds following initial power-up), there is reason to be concerned. If this occurs, turn the Servo 120a off immediately and carefully check all wiring and external devices in order to locate and correct the condition that caused the LED to light up in the first place.
Dec 27, 2010 | Samson Servo 170 Amplifier
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    How to switch protection off (red LED to blue)
    The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
    May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
    Thumping speakers - no power light is on - wired correctly
    the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
    Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
    Amp Power light will not go on. Protection light is lit- Thump sound in speakers
    It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
    Amplifier in Protect Mode - Troubleshooting
    Let me know if you have any other questions.
    Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
    No power at speaker side
    Is the power LED red or green?
    If it's red, try reading through the following page to make sure that the amplifier is the fault and not somethig else in the system.
    Amplifier in Protect - Troubleshooting
    Jul 15, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
    500.1 amp power lights blinks on and off
    Protection mode; follow this link to get a manual for the amplifier: http://mobile.jlaudio.com/products_amps.php?amp_id=439
    Below information is from the manual:
    Status Indicator Lights / Protection Circuitry
    There are three status indicator lights on the top of the amplifier. These are as follows:1) "Power" (Green): lights to indicate that the amplifier is turned on and operating normally.
    2) "Thermal" (Red): lights to indicate that the amplifier has exceeded its safe operating temperature, putting the amplifier into a self-protection mode, which reduces the power output of the amplifier. The red light will shut off and the amplifier will return to normal, full-power operating mode if the heat sink temperature drops back to a safe level.
    3) "Low ω" (Amber): lights to indicate that the impedance of the speaker load connected to the amplifier is lower than the optimum impedance load range for the amplifier. When this light is on, a protection circuit engages and reduces the power output of the amplifier. The amber indicator will also light when a short-circuit is detected in the speaker wiring (this can be a short between the positive and negative speaker wires or between either speaker wire and the vehicle chassis).
    There is only one condition that will shut down an undamaged 500/1v2 completely… If battery voltage drops below 10 volts, the entire amplifier will shut itself off. The green "Power" indicator on the top of the amplifier will turn off when this occurs. The amplifier will turn back on when voltage climbs back above 10 volts. This may happen in a rapid cycle when bass-heavy program material causes a weak charging system to dip below 10 volts momentarily. If this is happening in your system, have your charging system inspected to make sure it is working properly.
    For information on troubleshooting this amplifier, refer to Appendix E (page 21).
    Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
    348 people viewed this question
     Grubhead
    Grubhead
