FAX MACHINE I WANT TO DELET NUMBERS AND PUT NEW ONES ON
    Genius:
  • 2,120 Answers
Make /model?
Posted on Aug 31, 2008
How to run a report on a fax machine?
To run the auto dial and speed dial report you need to do the following:
Press Menu, 5, 2, then Start. The display will prompt you to the correct numbers. This will give you a list of pre-programmed numbers.
Jul 15, 2014 | Brother MFC-8220 Fax
How To Enable DTMF Digits on AR_M_280N Fax machine??
have you tried adding * 's they add a pause between numbers. You may have to add several, but that will put a slight delay in the dialing.
Jul 23, 2010 | Sharp AR-M280N Copier
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Aug 07, 2008 | Brother Office Equipment & Supplies
Can't copy
paper might be stuc in the machine at the roll.
Open remove piece of paper. Unplug maciine and try again
Jun 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Saving fax numbers
yes, you may.
If the Fax machine has a Memory function press it.
then type the number then enter.
or read the manual..
or visit www.canon.com
Dec 11, 2007 | Canon FAX-L800 Plain Paper Laser
Delet songs
If you reformat the player on media player or realplayer, it usually deletes the older file.
Nov 24, 2007 | Sears TGE MP3 Player
KEY PAD ON FAX MACHINE WON'T WORK
Have you programmed the  'rapid' (one touch) buttons or the speed dial numbers? (print a report of stored numbers to be sure)
Is machine set to fax mode?
Oct 15, 2007 | Brother IntelliFAX 4100 Laser Fax
22 people viewed this question
jasbo
jasbo
