Question about Sharp Televison & Video
I have a New LC-37D64U TV. If I move off center 45 degrees the color washes out. Are there setting or fixes for this?
    Problem Solver:
  • 30 Answers
This is called off axis viewing cone. There are no settings to fix that. Thats the nature of LCD Tv's
Posted on Aug 01, 2008
Sharp tv blinking codes
If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 18, 2017 | Sharp Televison & Video
Sharp,Aquos, LC-37D64U,Power & Sound, No picture?
try replaced main board
Manufacturer Sharp Part Number DUNTKE373FM03S Description P.W.B.UNIT
Jun 03, 2010 | Sharp LC37D64U 37 in. LCD HDTV
LC-45GX6U
The DC/DC converter went out on your set. When you take the top off of your AVC box look for a 4" X 5" circuit board mounted on the front left corner. I have seen these fail causing you white screen. Order the part from your local Sharp service center. Part # RDENCA089WJZZ
Jun 16, 2009 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
No Digital Audio From Sharp LC-37D64U
Try changing the the Audio Setup in the Digital Setup Menu.
If you have your manual, go to pg 11 and pg 28 for Digital Audio Output. If you need a copy of your manual, here's the link.
http://www.sharpusa.com/products/TypeManuals/0,1083,127,00.html
Page 11 has info on the problem and page 28 to solve it.
If that doesn't work, I would try downloading the latest software to fix is problem. Page 28
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=LC-37D64U&s_func_disp_id=27&x=42&y=11
May 22, 2009 | Sharp LC37D64U 37 in. LCD HDTV
Sharp D64 37" issue (Power+OPC light flash and won't turn on)
I'm going to guess your friend's model is LC-37D64U. ( 37" screen; D64 series)
It's sounding like a power supply problem for the LCD screen. It's somewhat common problem for big LCD screens. But, too early for your friend to be having this problem with the TV.
I would have your friend use the warranty at this point. Last thing you want to do is void the warranty by opening up the TV.
I would first try leaving the TV unplugged for 30 mins so it can reset. Then, try turning it ON again.
If that doesn't work, it warranty time.
If your friend just bought it, have them exchange the TV for another one. I wouldn't want a TV that has problems that just came out of the box. The Sharp TV only has a 1 year warranty. Upgrade warranty life if possible. A repair for a problem like this would cost about $100 for someone to look at it; and $200 to $400 for the part at a TV repair shop.
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
CRT TV Screen Colors Off
The tv needs degaussing (demagnetizing) unplugg the set tonight and then plug it and turn it on in the morning. You should hear a a "bonk" noise when the set is first turned on after being cold- this is the internal degausse circuit working and it should fix your problem if you don't hear the "bonk" sound or it does not fix your problem call arepair shop to have the degausse your set and possibly fix the internal degausse circuit.
Dec 23, 2008 | Panasonic CT-32HX42 32" TV
Volume not loud enough
are you watching movies frm a dvd player with the sound up, if so, turn the sound up on the dvd player remote and see hwo that works. eor, if its movies on normal tv screen, go to settings and click booster sound too hear better. if yours does not have this, ring your manufacture for a refunded tv with better speakr sound quality.
Oct 01, 2008 | Sharp Aquos LC-32D40U Television
Waher maytag
Pull your washer forward then tilt the top backwards until it sits at about a 45 degree angle. There should be a belt and 3 pulleys underneath. Remove the belt (one of the pulleys will move to allow slack) Ignore the moving pulley and the large pulley in the center. The third pulley is your pump. Try to turn it by hand, it should move freely. Presumably, it wont and will need to be replaced.
May 26, 2008 | Amana NAV5800A Top Load Washer
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
