Question about Pioneer Car Audio & Video
Someone gave me a Pioneer DEH-2700 head unit and didn't have any of the manuals. I have a 2007 Chevy Cobalt How to I install this unit into my car. I don't know which wires go to what or anything
    Problem Solver:
  • 8 Answers
The easiest way to do ANY car stereo head install is to first: buy a volt meter tester. pull the old stereo out and look for the yellow (constant current from battery) and isolate it so as not to cause a short circuit or blow a fuse (tape it so it doesn't touch any metal part of the car chassis) second: locate the Red wire (switch/ignition key connector) and isolate it too and last: the ground cable (black, no need to isolate it) turn on your volt meter in the 20 range position, connect the black cable from the meter to the black wire of the car (ground) and the red cable from the meter to the yellow wire of car and if it is the right yellow wire, it should give you a voltage of 9-12 volts result. This yellow wire its always (constant current) connected to the battery so as to keep any memory settings on the stereo head unit (like time, settings, stations, etc..) if it doesn't, then find any cable/wire that will do this with the IGNITION/KEY-OFF of the car and this should go to the also YELLOW wire of the head unit. Now take the volt meter RED cable and connect it to the RED wire (key switch/ignition) and it should not give you ANY voltage while the car is turnoff. Key ignition your car and as soon as you switch the car to ON (before your engine starts) then it should read EXACTLY 12 plus (12.47 or more) that's your wire that it gets connected to the RED wire of the head unit to turn the radio/stereo head unit ON. There may be other wires coming out of the same harness as the RED, YELLOW AND BLACK from the back of the head unit, like an Orange/pink wire which in older units provides Illumination and a DARK BLUE labeled ANT/REM which turns the AUTO ANTENNA ON, also another wire labeled AMP/REM which send an ON SIGNAL (switch) to any amplifier connected to the head unit (it does the same function as the RED wire from the car ignition cable that turns the AMPLIFIER/RADIO ON as soon as the key is turned ON) other wire such as a LIGHT BLUE OR GREEN which might be labeled ATT OR PHONE is to provide interruption to the head unit when a phone call comes through. THE REST OF THE WIRES should come IN PAIRS (almost always 4 sets) of the same color EACH with one of them (example: grey and grey with a BLACK line) which are your speaker connectors, like the grey above which would be connected to the POSITIVE terminal of the speaker and the grey/black to the GROUND. If these wire do not come in PAIRS, DO NOT CONNECT THEM to ANY of the speakers which would cause to blow/burn them out!! If your head unit comes with RCA/COAXIAL speaker out/ sub out/ labeled REAR/FRONT AND SUB, then they do the same function as the speaker wire pairs but with RCA CABLES that connect directly to any amplifier or crossover unit. Hope this helps. Phoenix One.
Posted on Nov 18, 2013
  • 3 Answers
The easiest way to solve this issue is to buy a wire harness for your car this will make the install alot easier. Its already color coded for your wires, so head out to your local installer or try best buy you might also need a stereo kit. Email me with questions on installs. jerree_cardenas2006@yahoo.com
Posted on Jul 25, 2008
Do you need to connect the yellow and red wires together if not used in a car on a pioneer DEH-X1950UB
Yellow - Connect to the constant 12 V supply terminal.
Red - Connect to terminal controlled by the ignition switch (12 V DC).
Jan 11, 2017 | Pioneer Car Audio & Video
I need operator's manual / instructions for Sony CDX-GT11W
The operating instructions and installation guide for the CDW-GT11W are available from the manufacturer's support site: https://esupport.sony.com/US/p/model-home.pl?mdl=CDXGT11W&template_id=1®ion_id=1&tab=manuals#/manualsTab . Click on the Manuals, Specs & Warranty tab. I needed to refresh the next page to download the manual (click on the circle with the arrow going clockwise). The direct link to the manual is currently https://docs.sony.com/release//CDXGT11W.pdf .
I hope this helps.
Jan 09, 2017 | Sony Car Audio & Video
JVC KD-R316 install in Valiant Regal I'm replacing the stereo in my car, it had an aftermarket system. The new unit has power and will show display and eject disc but won't turn on. Where did I messup
Envision how just a simple mouse pad could protect you from health problems that would definitely price you. Why not consider precaution when you still can other than offer with an issue, which you could have averted in the first place. Cell Telephone Accessories That You Ought To Have AmanStino
Jan 09, 2017 | JVC Car Audio & Video
Sirpintine belt routing
Before you take the belt off draw yourself a picture of the pulleys position and draw around the pulleys how they go on. I find that works. my car I can get my small camera low enough to take a picture.
Aug 27, 2016 | Jeep 2007 Grand Cherokee Limited 4WD
Usb
You need a new USB cable the new Kenwood and pioneer headunits have to have there own USB cable, go to you local audio dealer or go online and get a pioneer USB cable, they run $24 , I got my Kenwood one and they just have the option of total control from the headunit or not
Nov 16, 2012 | Car Audio & Video
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
Car Audio & Video Logo
139 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
