Question about Canon Office Equipment & Supplies
I have a Canon Fax-230 which produces faint printout either from the copy function or on receipt of a fax. I have tried cleaning internally without making any improvement. Are there any voltage levels which can be checked and if necessary, adjusted? Tony Chalkly
Dear Tony Chalkly:
It's a bit late after your question, but I have a working Canon Fax-230 plus paper rolls that you can have if you pay for the shipping and handling. Where are you located and are you interested?
Posted on Dec 11, 2010
It does not produce a dialing tone and it doesn't fax nor recieve
Here are some things to check:
1. Is the unit attached to a direct line (not one that goes through a local PBX)? Many fax machines have problems with internal connections.
2. Is the phone line connected to the proper port? The port for the external phone normally will have a picture of a handset. The other port is used to connect to the phone outlet.
3. Try a new phone cable between the fax and the phone outlet.
Here is a link to the user manual if you do not have one:
https://content.etilize.com/User-Manual/10203508.pdf
Apr 29, 2015 | Brother Mfc-8220 Laser Multi-Function...
Canon Fax L220 black and dirty printout. How to solve it?
try to clean inner glass and white plate of fax machine with opening the upper cover
Aug 07, 2013 | Canon Office Equipment & Supplies
My Canon 8530 printouts has wiped-out/faint prints in between prints. when you at the photocopy made by canon 8530 copier, you will see that some horizontal portion of the copy are faint or wiped-out and...
hi
please press the maintance of the printer and perform a Clean Print Head operations
either form you PC or from the printer directly.
Clean the print head and you should get better output
good luck
Aug 29, 2011 | Office Equipment & Supplies
Canon JX200 printout
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=338&modelid=14787
Try these user guides, but I don't think that the fax is capable of storing each fax that it sends. If you need a copy of said document, you might have the person fax it back to you. Hope this info helps.
Aug 18, 2009 | Canon Office Equipment & Supplies
How can i check the copy counter of Toshiba Fax E-Studio 50F
press
function
7
monitor key slowly 4 times
set
2 for on
set
stop
stop
then
function
64
set
wait for printout
Mar 18, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Copy Quality
The CIS scanner has one of the LCD bits bad. If it is new, claim a warranty repair. Otherwise, strip the scanner out and go over all the solder joints
Feb 27, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
189 people viewed this question
old marine
old marine
