Computers & Internet Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I disable the mouse pad on my ASUS K52F Lap top? I prefer the remote mouse but I keep touching the mouse pad when I type and the cursor just goes someplace else.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
821
Points
Hey man had the same prob but found how to fix it :). go to control panel click hardware and sound. then you will see devices and printers, under that will be, add device, add a printer, mouse. Click mouse! Then click the tap ELAN, there is a box to check, it says, "Disable when external USB mouse plug in". there you go. Hope that help.
Blake
Level 2:
  • Expert 136 Answers
  • Posted on Feb 15, 2016
Blake
Expert
Level 2:
Answers
136
Questions
Helped
35430
Points
159
Look at your f keys and see if you see an mouse or a finger then hit the fn plus that button to turn off/on your mouse pad
The cursor bounces around when I type, especially in Word. Do you know how I can correct this problem? I read that disabling the touch pad might remedy the problem; if so, how do you disable the touch...
As you type, your wrists could be close-enough to the touch-pad to move the mouse-pointer.
Click Start
Click Control Panel
Click Mouse
Change the setting to disable the touch-pad.
I would like to lock my touch key pad (I prefer to use mouse). Currently, I keep hitting the pad with my palms as I type and sending the cursor all over the place. Can you help? Thanks Denise
there usually is a certain way to temporarily disable the mouse
look for something like that on the "F" keys (F1 F2 F3) (like a cross over a picture of a mouse pad)
you might have to press the "FN" key and "F" (depending which one had the picture) at the same time .
if not check for options (try right clicking mouse pad icon in system tray maybe) or look for an option the control panel
tell me if you got it figured out
1helpful
2answers
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
I need help disbling this touch pad
You need to look into the user information manual for that notebook to see if there is a disable function. If nothing else works, Place tape over the touchpad and that should help. Additionally, you can look at your mouse sensitivity settings in Windows under control panel and reduce the sensitivity of the mouse.
2answers
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
1helpful
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Mouse keeps shifting the cursor to a different place in document
On touchpads if you touch the pad twice in quick succession it acts as a click and the cursor will move to the mouse pointer location. In mouse settings disable "tapping"
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
1helpful
3answers
Moving cursor.
well there is a few things that could possibly be happening. if it is a touch pad or a wireless mouse something like a cell phone sitting close enough to them could be causing some interference. the second one is that you could possibly have the mouse keys turned on where you can control the mouse with the keyboard.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
