Question about Brother HL-2040 Laser Printer
Paper light on and can't reset, has paper in cassette
Is there aproblem with the paper lift assembly and can I get the parts to fix this?
  • Anonymous Aug 05, 2008
    flashing paper light won't go off and printer wont print. I tried putting in paper, turned peinter off, then back on. - don't know whatelse to do. Please help.
  • minchevy Nov 24, 2008
    Does anyone have a solution to this problem?
It is my printer problem. Anyone help to solve this problem
Posted on Jul 26, 2008
This error code indicates a problem related to paper cassette lift mechanism. First thing that you will need to check is, if the printer makes some strange noises at initialization, when the printer is trying to lift the paper inside cassette. You can verify if the lift mechanism on the printer is ok, by removing paper cassette and press the 3 small white switches on the left of printer. At this moment the printer is trying to lift the cassette and you will see a gear that rotates on the right side of printer. Also verify if the GEAR LIFT Z64 is intact by opening the gearbox(the big one from the gears from the right side of paper cassette). This gear is cracked in most cases. Replace it.
May 06, 2014 | Kyocera FS-4000DN Laser Printer
Paper feed results in a clicking and no feed
This sounds as if the paper pick up assembly is not lifting the paper-up to meet the rollers. This is like a ratcheting sound when lifting. When the paper gets high enough it hits a sensor arm and the copier will indicate paper in the cassette. If it doesn't lift it will quit but will never indicate paper in cassette. Does the other paper cassette feed? I know I've had to replace the paper pick-up assembly before because of this problem and is very expensive. Good luck.
Sep 27, 2011 | Canon imageRUNNER 210S Copier
I have a canon imagerunner 330s. It reads load paper and it is already full. Is there a sensor that went bad?
Sounds as though the lifting mechanism for the paper Pick-up assembly has gone bad. When closing the paper cassette you should hear a ratcheting sound, this is the lifting of the paper to meet the paper pick up rollers. It should stop and the display should indicate paper is present. If it continues to ratchet and never indicate the paper is ready, then the P/U assy will be the problem. The whole paper pick-up assembly will have to be replaced. In all my years of working on this model, I never successful in repairing the assembly.
Jun 27, 2011 | Canon ImageRUNNER 330s Copier
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Hello sharp sf-2027 error code F3
This is a paper feed tray problem. Check there is no paper behind the cassette. There may be a tray lift problem and this can be caused by paper being trapped behind it. reset the code once fixed by switching the machine off and on.
Good luck
Oct 10, 2010 | Sharp SF 2020 Copier
I have a Toshiba 3560 copier. Its stating 'CASSETTE OUT OF ORDER' Any suggestions on getting this beast up and purring again?
Either there is paper trapped behind that cassette preventing lifting mechanism from lifting paper up to feed height.....or the lift drive assembly has failed. Pull the tray out until it stops, then lift front side of cassette to release/remove it. Look into opening towards right. If no paper, turn copier off then on....this should clear the 'cassette out of order' message. Now, reinstall your cassette. Make sure there is less than approx. 1/2 inch of paper in cassette, then insert cassette fully. It should attempt to raise up....if you hear popping noise during lifting process, the lift drive assembly needs repaired.
Sep 15, 2009 | Toshiba Office Equipment & Supplies
MFC886DN will not pick up the paper in the lower tray.
first, most common problem is the rear stopper in the cassette is pressed too tightly against rear of paper. leave 1/8" gap between stopper and rear of paper. if that doesn't help, pull cassette out and locate gear on left side of cassette bay and make sure it is not dislodged.
good luck,
Apr 07, 2009 | Brother MFC-8860DN Printer
Hp 4700n
Have you would try a different paper cassette.
Usually that clunking noise is associated with gears not mashing.
Is the lifter lifting the platform or not?
There might be something above the paper tray, maybe even the paper input assembly preventing the paper platform from reaching the top.
Check these and let me know what happens.
Oct 03, 2008 | HP LaserJet 4700N Printer
Not printing
there is paper jam or there is the dust in some sensor
Sep 12, 2007 | Epson AcuLaser C900 Printer
Brother HL-2040 Laser Printer Logo
43 people viewed this question
James Cagle
James Cagle
Jim Keysor
