Question about Lands Phones
I have a GE model 28213EE2-A Dect 6.0 with base and additional handset-no answering system. The handsets go out of registration all of the time. I have called Thomson/GE and I get a run-around. They say send it back and they'll send a new one out in 4-6 weeks, but the folks on the forums say the replacement phones have the same problem. HELP, PLEASE!!!!!!!!!!!!!!!
  • 8 more comments
  • Anonymous Sep 15, 2008
    The handsets go out of registration but only when in the base station cradle.  Have relocated the base station to determine if there is an interference problem.
  • elswoods_99 Sep 26, 2008
    I thought it was interference too, so I tried moving the main base away from ANYTHING electrical and it did NOT help. The phone simply will not work and it is annoying! Does anyone have a solution?
  • gregwhite75 Oct 10, 2008
    This is the most annoying set of phones I have ever owned. I, too, have the problem of the phones not registering properly. I have changed the location of the base station and nothing seems to work. My advice to anyone out there doing product research is to not purchase this phone set. It looks to not be an isolated issue.
  • Anonymous Oct 25, 2008
    Identical problem, Identical Phone. I'll try moving the base station away from my iMAC.
  • Anonymous Oct 31, 2008
    We have the same phone set. It seems if we place it on the charger, it goes haywire. I am considering a hammer for the solution/satisfaction.
  • bombtech1970 Nov 16, 2008
    I have the GE phones also and same problem. This is the most annoying phone set I've ever owned. They are inoperable more than they work. My vote is for the HAMMER solution. Too bad I tossed my receipt and the box. DON'T buy these phones!
  • Anonymous Dec 13, 2008
    I've also had them replaced once and still have the same problem.
  • lonnsimm Dec 22, 2008
    I have the G.E. 6.0 DECT model 28213EE2 also and the phone doesn't work more-so than it does.  This is annoying phone system.  It advertises "NO INTERFERENCE" , but in the manual, it says if the phone does not work properly, move the base station to another location.  We have done this a few times and this phone still has the following problems ( while connected directly to the wall) :  Phone does not ring all the time.  2. Push to get dial tone and get "beep-beep-beep" alarm and no dial-tone. 3.  cannot pick up the extension if someone is calling you from downstairs to "PICK UP!"  4. phone charges then acts as if it needs to be charged.  I don't recommend this phone system!
  • klm9 Mar 26, 2009
    Handsets out of registration - and do nothing but beep - this phone system is like the flu - if you don't have it, stay away, if you do have it - get rid of it.
  • Anonymous Apr 24, 2009
    same as everyone else.
I too have the same problem with this phone. It goes out of registration and the caller ID does not work. It works on all the other phones in our house.
Posted on Oct 05, 2008
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Aug 17, 2010 | Vtech DECT 6.0 Digital Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Ge model 28213ee2-a 2nd handset doesnt ring when a call comes in
assuming all the settings are correct, and sometimes there's a tiny switch on the handset for ringer, that has to be on, try the 'page' feature [the button on the base to make the handset ring to find it] - if that doesn't work, there's a very good chance the ringer itself is bad. i've seen that many times.
May 26, 2009 | Uniden Cordless Phone
One handset doesnt ring
There should be a ringer tone and volume control on the second handset. Sometimes there is a ringer on/off switch on the side of the handset.
If that doesn't work, then there is a possibility that the speaker is broken.
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
I CAN'T REGISTER HANDSET FOR GE MODEL 27911 DECT 6.0
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Apr 02, 2008 | Lands Phones
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
Lands Phones Logo
282 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
