Question about LG WM-2277HW Front Load Washer
Lgwft1031tp be onwasher no hand bk what does it mean pls
  • 639 Answers
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
I have a Canon Pixma MG printer . There's orange lights at BK & CL that are blinking? What does that mean ?
means that the toner cartridges are just about out of ink and need replacing
BK=black and CL= color
Mar 15, 2016 | Canon Office Equipment & Supplies
Ibhave a jitterbug touch and in the left hand corner it says safe mode what does that mean and how can I change it bk if I need to
take the battery out of the phone and restart the phone. Without knowing a model number and brand of phone it isn't possible to give a better answer
May 27, 2015 | Cell Phones
How many turns for pilot screw on a senda sm 125t?
screw it all way bk in and bk it off 1 and half screw if you no what i mean
Nov 20, 2014 | Derbi Senda SM 125 4T Motorcycles
My phone wont allow me to talk through handset only handsfree how do i change bk
There should be a setting in the phone set up menu where one can select permanent normal or hands-free. In other words deselect hands-free! Also remember this may not be called hands-free on all phones, so look out for similar meaning settings/selections.
Jul 25, 2014 | Alcatel Cell Phones
Whirlpool cabrio makes grinding noise on the wash cycle
On this style washer the motor has a belt and pully type clutch under the machine called a splutch.There has been an ongoing problem with the nut coming loose and dropping the belt/pully down which in turn hits the safety shield.
Mar 31, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Sirrrr in my lcd tv displaying k123 pls give me solution fastly
sir this tv sharp with the modle no. is 22L50M-BK
Its is working but will display screen in lcd show the massege K123
so this reason voloume and chanal change not working
please tell me this
Dec 25, 2012 | Sharp LC-22L50M-BK 22 inch Multi-System...
Why won't the brake lights turn off on a 1988 vw golf. Just started having the problem
first check for a faulty bk lite switch----its on the bk pedal arm up under the dash. alittle spray of electric contact cleaner usually does the job, but first work the sw by hand to see if this helps.....other wise if it is not in the switch, you have a ground at the rear of the car or in the bk wiring.... hope this is helpful
Mar 02, 2010 | 1988 Volkswagen Cabriolet
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Can't retune sharp aquos lcd tv
This is the best place that's near the manual you need.
They have the LC32D44E manuals, but not the "BK" at the end. I think the "BK" just means BLACK.
But, I think it will work for your TV.
Here's the link:
http://www.sharp.co.uk/page/downloaddrivermanuals#
Click on the "Sharp Europe - Manuals and Download "
Then, Operation Manuals
Then, LCD-TV
Then, put your TV model# for the search.
Apr 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Magenta clogged
OK: Lets give you a hand and an advice, if you dont mind:
the advice:
brother uses DYE-ink for C/Y/M which contains an amount of glycerol and some cleaning fluids:
I guess you run 100ml ink boxes (so you might do a math operation ;-) for your amount needed)
Use 25 ml of glycerol (85%- glycerin alc from drugstore) and mix it with 75ml of dye ink very well.
Use 5ml glcerol and 95ml of ink for BK. This has to be shaken very well, because BK ink contains of diffrent chemiclas than Y/M/C.
Now the hand:
Make sure the CIS is placed well in place at printer side (and some how secured).
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will turn to maintenance mode (light will flash).
press 7 -6 -4 and then start bk-copy.
Machine will initialize the "carts", refresh ink in tubes and ph and delete all air which might be within the ink system (this could be the reason why you cant print mag!). It runs an extra power cleaning, too.
When finished, press 7 -6 -3 then start bk copy to do a power purge.
When finished press 9 then 9 to leave the maintenance mode. machine comes up in normal state.
Do run a test print and check all squares.
If you cant see any mag the ph is definitly clogged and needs replacemnet (brother ph techniques cant be cleaned by fluids or outside the system! So dont waist your money on cleaning carts which wont work!)
Nov 03, 2008 | Brother MFC-5460CN All-In-One InkJet...
LG WM-2277HW Front Load Washer Logo
19 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
