Question about EliteGroup P4VMM2 V8.1 Motherboard
Apg video card
What is the compatible agp video card for my P4VMM2 V8.1 motherboard
  • lokster Oct 11, 2008
    would an 8x/4x low profile Radeon HD3450 with 256mb of ram work?
    Scholar:
  • 93 Answers
Use AGP 4x card. It can either be 0.8V or1.5V.
Using the wrong voltage card with the wrong motherboard may result in damage in board and card.
Also, if you install a card that is not compartible voltage with motherboard specification, the card will not run.
Good luck.
Posted on Jul 25, 2008
Is gfx 5500 compatible with p4vmm2 ?
Hello !
I was looking over this motherboard over the internet. I saw that it has an expansion slot of AGP 4X slot. Geforce FX 5500 is also AGP compatible.
So to get to the point, yes, they are compatible with each other.
All the best.
Aug 03, 2011 | EliteGroup P4VMM2 Motherboard
This Is My Processor Type x86 Family 15 Model 4 Stepping 4 GenuineIntel 2799 Mhz What Video Card Sofware That compatible for this processor..?
If your motherboard has an AGP expansion slot you can install any model AGP graphics card in your computer.
There are many AGP graphics cards on the market, and depending upon your requirements there is a card to suit eg. a high end APG card with 1Gb of RAM would suit graphics intensive video games.
I suggest you identify the make and model of your motherboard then see your friendly compiuter shop and see/ask what graphics card is available that suits your needs.
Jun 21, 2011 | Computers & Internet
My p4vmm2 rev.8.1 has only 256mb memory card and 128mb video card, my question is what would be the maximum bytes for memory card and video card can i install. Offcourse the compatible hardware..tnx
Looks like the max is 2 x 184-pin DDR DIMM socket support up to 1 GB, which means you can get 2 512MB DDR266/200 2.5V DDR SDRAM chips.
as far as video cards, it will accept any AGP 4x or lower card. You could also put a PCI video card in it, but AGP is better.
Dec 28, 2010 | EliteGroup P4VMM2 V8.1 Motherboard
I want to upgrade my graphic card
That video card won't work on your system board. The video card requires a PCI-E expansion slot, but the system board has an AGP slot. You'll need to look for an AGP video card. I tried looking on the site you gave for the card you were considering and they don't seem to have any AGP type cards, so you will need to shop around some more.
Nov 19, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
VIDOE CARD PROB?
reseat the video card in the slot. then use the cmos reset jumper on the motherboard (when the power is off). if this doesn't fix the issue, then the card may not be compatible with the agp or pci-e slot that is on your motherboard. If this doesn't work (I am assuming your motherboard also has a default (onboard) vga out port - then go into the bios and set the primary display device to be the agp or pci-e slot.
Sep 26, 2008 | EliteGroup P4VMM2 Motherboard
Upgrading VIDEO CARD
If your motherboard's graphics slot is AGP and your graphics card is AGP then it should be fine if your motherboard is PCI-E and graphics is PCI-E it also is fine make sure your motherboard and graphics are compatible.
May 29, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Brand new geforce 6100 pm -m2
This is for the EliteGroup P4VMM2 motherboard. Please remove any newly added video card. One done boot the PC. Windows should load & function (Including video display). Yes?
Restart the PC & press the delete key every 2 seconds untill the bios menu loads. Opem the manual to page 33. Change the Primary Graphics Adapter from PCI to AGP. Save & exit the bios. The system will begian to restart. Press & hold the power button untill the PC shuts down. Unplug the power cord from the PC. Install the AGP card & connect any additional power to the video card if required. Double check all data & power connections for good fit before closing case. Re-connect the power cord & start up the PC. You should have display. Allow windows to finish loading & install the AGP software. Than update windows.
Who ever heard a single long beep. This means the video card may not be seated fully & or correctly. Remove the AGP card, blow out the AGP slot with canned air. Take some alcohol dripped onto a cotton swap. Clean the AGP's copper contacts & clean/wipe the copper within the AGP slot as best as possible. Allow time for alcohol to dry. Re-insert the AGP card, firmely & evenly.
Any more troubles? Please list the issue here. Need manual for the EliteGroup P4VMM2? Click on this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Good Luck!
Mike
May 18, 2008 | EliteGroup P4VMM2 Motherboard
Video card
Some arguments say a PCI Card, other say a AGP Card. Among the PCI Card supporters, are PCI eXpress (PCI-X), and PCI Interupt PCI-I), they will not touch a PCI that is not one or the other.
Dec 27, 2007 | EliteGroup P4VMM2 Motherboard
COMPATIBILITY PROBLEM
u have an agp slot on the motherboard. no good latest cards come on agp. go for a geforce 6200 agp. shud be able to find that at very low price.
Dec 05, 2007 | Computers & Internet
VIDEO CARD COMPATIBILITY
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself,  the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=413&areaid=2&LanID=0
This board has a 4x AGP slot
Oct 09, 2007 | Intel Motherboard
EliteGroup P4VMM2 V8.1 Motherboard Logo
122 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
