Question about Toshiba MW20H63 TV
Won't keep digital signal
Brand new TV - is setup for cable and keeps going back to analog. Defaults to analog when TV is turned off - or - auto timer comes on. Keeps saying the digital signal is weak. Every other TV in house works perfect. Had it working perfect yesterday on cable after messing with it for an hour and this morning it is back to analog.
HELP or I'm stuck with the monster!
    Genius:
  • 1,074 Answers
Since the tv is new i believe that you have warranty on it from the store you purchase it take it back for a replacement,obviously it is the tv that is having the problem since the other the tvs in the house are working fine.good luck.
Posted on Aug 19, 2008
    Sergeant:
  • 308 Answers
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Posted on Aug 03, 2008
TV WAS USED FOR CABLE BUT WANT TO USE IT FOR TV ONLY
Is your TV analog or digital? If analog then it will work with the cable but not with over the air antenna signals. You will need an adapter box between the TV and antenna. Use "digital tv converter" for a search on eBay.
Aug 15, 2014 | Televison & Video
No instructions! do i need a lead to detect tv signals?
By "TV" Signals, do you mean video signals? If so, the WIndows video player does a good job of playing most varieties. If you mean off air or cable TV signals, you'll need a receiver. Look at the Elgato, or similar brands. They plug into a USB port and are capable of receiving analog and/or HD ATSC signals, or cable signals. Keep in mind that digital cable signals are generally a mess to identify and sort out because they are on different digital channels and subchannels. You may need a digital to analog converter in front of your Elgato to keep from going nuts trying to fighure out where everything is.
Nov 14, 2009 | Computers & Internet
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Digital audio not recieving signal from dvd player
I have the same problem on the same receiver. I split my cable and plugged one side directly into the system, and the other I used a 300/70 ohme converter to plug into the fm antenna side. This helped to get stereo on local stations. I think I am going to have ot go for an outdoor antenna to get anything more.
May 31, 2008 | Accurian AVR-5048 Receiver
Digital or Analog>
I believe this tv has a built in digital tuner. To verify this, using your remote attempt to change the channel to say 3-1 or 3.1 if you have a digital tuner this is how a digital channel will show up. Also if you go into your menu under channel scan you should see a choice named dtv. And finally on the back you will have a coax connecter named dtv. The latter is not always true. If it does turn out to be standard format tv, you can still purchase a digital set-top box that will decode digital for you. Keep in mind that you must have a good uhf off air signal in your area to recieve digital signals. Good luck.
Feb 20, 2008 | Televison & Video
No signal from either antenea A or B
enter the setup menu and select auto programed function,
Nov 15, 2007 | RCA F38310 38" TV
Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Apr 09, 2007 | Pioneer VSX-D514 Receiver
Toshiba MW20H63 TV Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
