This has to do with the detergent change that happened recently. Go to
the link and it will explain what is causing this in more detail as well
as how to get better results.
http://www.appliancerepairlesson.com/2011/02/24/dishwasher-is-no-longer-cleaning-film-and-debris-are-left-on-dishes/
Good luck
First
perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar
into the bottom of the dishwasher. Keep the temperature at the highest
setting possible and perform a wash cycle.Then start using a dishwasher
most probably that would solve the problem. If this does not solve the
problem then there must be some parts worn out or faulty creating the
problem.
There are many probable causes of failure .
To
clean the dishes the water temperature is essential.It the water is not
hot then the dishes will not be cleaned properly.So check the water
temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
I had the same problem and found out it was calcium deposited in the water so I bought a photonic water filter and this resolved the frosty film on my glasses and stopped the streaking when cleaning stainless steel. http://www.steelcleaner.com
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
