Question about GoVideo Go Video DVD/VCR Combo
I have the Zenith XBV443. I'm trying to copy saved programs from my dvr on my tv to dvd discs. My neighbor has a simular model yet we can't find out why I'm unable to do the same. What do you think is the problem? Is this model only good for coping dvd to vhs?
    President:
  • 1,140 Answers
The Zenith player/recorder will be able to record to DVD from an external input such as a PVR. The most likely reasons you are unable to record successfully are:
1. The TV / DVR is not connected to the Zenith recorder correctly. You need a separate cable for recording. You cannot record using the cable that is connected for playback of DVD discs.
2. The TV / DVR does not have "VIDEO OUT" sockets
3. You have not selected the correct external input on the Zenith recorder
If you can let me know the brand and model number of your TV / DVR and how it is connected to the Zenith DVD recorder, I can let you know why it isn't working, how to make it work, and even draw you a setup diagram, if required. It's very difficult to give you the correct answer without these details.
You Zenith DVD recorder will record from the DVR - the real question is, can the DVR send video to the Zenith DVD recorder . . . ?
Regards,
BElectric
Posted on Feb 17, 2011
SOURCE:
Zenith XBV443 no picture or sound after reading DVD disc
see this causes and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Sep 30, 2012 | Zenith XBV443 DVD Player/VCR
Need a manual for a Zenith VCR/DVD combo Model XBV443
HOW DO I REMOVE THE FEATURE SHOWING "SUBTITLES AND DIALOG?
Nov 02, 2010 | Zenith XBV443 DVD Player/VCR
What DVD should I use to record TV programs. I
Most dvd recorders will only accept dvd+r's or dvd-r's, if yours will not accept dvd+r's then try dvd-r's.
Sep 02, 2009 | Zenith XBV443 DVD Player/VCR
Need a manuel
need to program the remote, need the code for it
Mar 20, 2009 | Zenith XBV443 DVD Player/VCR
Can't turn off progressive scan on my dvd/vcr player.
Page 18 of the operating manual cites this, to reset to default viewing mode:
1) Remove any disc from the unit and close the disc
tray. See that “dISC” is displayed on the display
window.
2) Press STOP and hold it for more then five
seconds before releasing it. The video output will be
restored to the standard setting and a picture will
once again be visible on a conventional analog TV or
monitor.
If that doesn't work, please let me know.
Mar 19, 2009 | Zenith XBV443 DVD Player/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Owners manual for zenith zry316 DVD/VCR
http://www.retrevo.com/support/Zenith-XBV443-DVD-Players-manual/id/374dj499/t/2/
heres the manual you needed.Thank You for asking us.Please do rate if this solves your problem.
Sep 22, 2008 | Zenith XBV443 DVD Player/VCR
Message reads NO DISC on Advent model DV1418A
Is the disc an original DVD or copied. If it is copied and the DVD is old the DVD will not read it and tell that there is no disc. You also need to have the laser checked. Did it do it for a number of disks or just one. If you have only tried one disk, try another
Jun 08, 2008 | Recoton Advent Advent DV1418A 14 in....
Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Apr 07, 2007 | Zenith XBV443 DVD Player/VCR
GoVideo Go Video DVD/VCR Combo Logo
174 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
