Question about Haier Heating & Cooling
It sounds like there is water inside the unit from a recent bout of rain storms. I found no way to empy it - is this going to cause damage to the unit or do i just run it as usual and it will go away?
  • 446 Answers
What do you mean water? pls elaborate clearly, was it spilt type or what?
or it could cause by dirty filters, clean filter with vacuum and reinstall
Posted on Jul 25, 2008
Hello. I have a Pontiac G5 2007. Rain water flooded the floor mat of my car. All the windows and sun roof were closed. The sun roof was dry, what might have caused this. Thanks in advance.
I had this problem once with mini-van that I owned and it turned out that the grill on the outside, at the base of the windshield had plugged with tree debris and the water could not find the drain hole so it backed up and came in under the dash and filled the cavity where the blower motor for the heater sits.
I cleaned that out, pulled the blower motor and dried the tub it sat in which by then had mildewed, then put it all back together and things were fine. The blower motor had shorted out by the way so I had the fun of buying and installing a new one.
Apr 01, 2017 | 2007 Pontiac G5
Why is my pride pursuit scooter dead... no lights anything
Sounds like the water has damaged the controller or the wiring.
Oct 19, 2014 | Pride Pursuit Xl Heavy Duty 4-wheel...
Why does my 2003 Mitsubshi Outlander misfire after a rain storm?
Check for water getting into electrical compnents.
Aug 30, 2014 | Cars & Trucks
Ducane grill gets loaded with water
Do you not put a cover over it this will stop the rain , they are not water proof there are vents for when you are cooking sort of flue vents .
Apr 19, 2012 | Ducane 4200AFF Gas Grill
Our penquin dometic air conditioner in the bedroom pours leaks lots of water when the unit is on during rain storms. Water leaks into the ceiling and also out the unit.
Sounds like base gasket at roof is loose or defective to start with. Try removing ceiling assembly enough to tighten 4 bolts that secure roof unit to inside bracket. Do not compress too much, just snug them all evenly and see if water slows or stops. If not, you will have to remove upper unit (roof) and replace gasket and re-secure but don't tighten to excessive, only compress gasket approx half of original thickness. Also make sure upper unit is aligned properly with opening of roof.
Sep 23, 2011 | Dometic Rooftop RV Air Conditioner
AC unit is laboring to turn on, there is a slight burning smell cominig from the back of the unit, then the breaker trips. This all hapened after a recent bad rain storm and the basement had about a...
Sounds like the rain storm could have brought on some capacitor issues. Go to the back of your outside unit and look inside the access panel with the electrical warning sticker on it, if the capacitor is bowed up at the top, it needs to be replaced. If it turns out to be the capacitor, follow this link for a new capacitor replacement kit, it will save you hundreds of more dollars than calling an HVAC repair company to charge you enough to break open your piggy bank. The kit also comes with the proper tools and parts needed as well as detailed instructions on how to replace the part yourself. http://hvacrepairkits.com/index.php/content/article/68
I hope this helps!
Aug 17, 2011 | Honeywell Heating & Cooling
My stereo is installed outside in my BBQ island. I have a cover for it to keep it dry. We recently had a huge rain storm and water got inside the cover. Although there is still power running to the...
If water did get into the cover of it the circuit board may have got condensation inside and on it. There is no way to tell if there is condensation is to look inside the amp and inspect the circuit board. Also I would not run power through it because if there is condensation on the circuit board you will fry the components.
Dec 23, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I can hear water sloshing whenever I break suddenly. Sounds like it's coming from inside the right side dash or door? We recently had 7 in of rain within a two day period & my '05 Camry sat in the...
The water probably went down between the window and the door. On the bottom of the door is a drain hole, with all that rain it looks like the water in the door washed some dirt or something over the hole and stopped it up but not before it went inside the car and onto the carpet. Just unplug the hole with a small stick or something and watch for the water drain out. Open the doors and let your car dry out. Should be O.K.
Sep 13, 2010 | 1999 Toyota Camry
2006 VW Jetta has a water leak somewhere cause yesterday we had a pretty strong rain storm and both of the back floor boards were full with 1' to 2' of water. Went to dealer and they said it was the door...
They could be right but check your cowling.. it could be clogged up with leaves and pinestraw.....causing the water to come inside instead of draining under there car
Dec 08, 2017 | Volkswagen Jetta Cars & Trucks
Water coming out of my top vents......
Go outside and see if you can spot a plug up in the drain tube. Some insects will build nests inside the proper size tube and plug it up so that condensation generated by normal operation is not allowed to drain from the unit. Other times, fungus or algae will cause the plug up.
Your plug up may be internal to the machine as well. This might be relieved by swabing out the plug up from outside by means of a fine flexible cable or weed wacker line - be careful!! Drain lines are often hidden very well requiring great detective skills.
Aug 23, 2009 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
