Greetings, The marble on my Track-ball wireless controller is sticking. Is there a way to unstick it. I know I am not suppose to oil it.
    Novelist:
    Scholar:
  • 160 Answers
The easy way is to use a damp cloth, hold it against the ball, and rotate the ball to clean it.
If that doesn't clear it up, usually you can open it up from the back (tiny screws) and clean the rollers that the ball turns on. TAKE OUT THE BATTERYS! Use a toothpick, tweezer etc to pull out the fuzz that builds up. A Qtip with a bit of alcohol will clean the black smudges on the roller, but don't drip too much.
Hope that helps.
Posted on Jul 25, 2008
I accidentally fumbled and dumped an entire cup of coffee on my Logitech marble mouse! I extracted the ball, dried everything off inside and out, and even cleaned the little optical window inside the...
Turn it belly side up. If there is a retaining ring turnit counter-clockwise to remove it Pop out the ball.
There are three little bearings about the and shape ofa BB Take a Q tip and dry and or remove any debris on the BBs There should also be a little black rectangle. This is thewindow that the sensor looks at the ball through, Clean/dry it with Q-tip. Put it back together and try again.
Mar 18, 2011 | Logitech Marble Mouse USB (LOM9043600403)
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
The marbles go up the tower just fine, but most of the time they all get backed up at the first magnet. sometimes the 2nd or 3rd marble will hit hard enough to push to first one out, but most of the time...
What I did was spread the first magnet block apart from the track part underneath it slightly. I used my thumbs to bend them a apart a little more. Now each ball gets slowed down but not stopped by the top magnet, I didn't do anything to the down side magnet and the balls pass right through.
Of course just don't use too much strength. It just takes a little more separation.
Dec 22, 2010 | Dmm Mega Brands Magnext iCoaster
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
The ball on my blackberry sticks
The track ball slot could be dirty. You need to contact the manufacturer and have them clear the track ball for free.
Have a great day!
Jan 08, 2010 | RIM BlackBerry Storm 9530 Smartphone
My track ball scrolls on my blackberry curve but niether the keypad or the track ball works. how can this be soved without buying a new phone?
try cleaning the track ball with a qtip dipped in alcohol or nail polish remover.. It could be that the track ball isn't "reading" correctly due to oil, etc.
Nov 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
Ghb middle marble
Check the settings in the bios to enable the track ball. Most of the time that is where it is enabled or disabled. You can also check Dell's support website for additional software that may allow you to configure additional settings (similar to IBM/Lenovo Thinkpads).
I don't recall the specific key to press to get into the bios, its either F1, F2, F10. You need to do this from a cold start when the laptop is off. Press the power button and when you see the Dell logo, look for the bios settings key to press or press one of them that I suggested. Sometimes this may go by quick so you need to be quick about it as well.
Hope this helps!
Oct 17, 2008 | Dell Latitude C600 Notebook
Saitek st290 Lube
I'm going to assume that you're refering to the central spring slider on the stick. The spring follower at the base has to slide up and down the shaft to provide spring pressure as the stick moves away from center. This plastic follower has a tendancy to gall the plasic it slides over on the stick shaft resulting in jerky stick movement. You can solve this problem with any wax based lubricant. I used a chapstick, but there are sprayable wax lubes that would be easier to apply, you can find them at hardware stores. Be careful with oils. Plastics are made from oil and the wrong ones will disolve it. WD-40 is a safe oil but use it sparingly and only on the shaft. Avoid using penetrating or cutting oils, they will disolve the plastic. You should test any oil on a foam coffee cup.
The stick's internal gimbals are already well greased and don't need relubed and the throttle is supposed to be a little stiff. I've had good results with both WD-40 and waxes. The waxes are a little harder to apply but last much longer
Aug 20, 2008 | Saitek ST290 Joystick
Computers & Internet Logo
David Payne
David Payne
