Question about Vestax Pmc06proa Thin DJ Scratch Mixer System
Both Jack Plugs have NO output
Can you supply circuit diagram / schematic so I can trace fault?
Regards Bill Finney
  • dj rex Apr 03, 2009
    I have an first generation 05pro and the rca outputs stopped working.  It just hums. Does anyone know how to fix it?
Ger a convertor
Posted on Dec 18, 2008
Have Manual and Guides
What outputs are you having trouble with? Headlights, taillights, blinkers, etc... If you have a volt meter or test light the lowest cost option would be to got to a dealer and have them print out a schematic on the circuit you're trying to diagnosis. If the tailight isnt working for example you could disconnect the harness that goes into the tailight housing and backprob the wire that is supplied 12volts when the key is tuned in the on position. By grounding the test light to you're negitive side terminal of that battery (or other solid ground) you can safely diagnosis many electrical issues without a manual or diagram of the electrical circuit. I'm our example above if I had no power form one of the 3 wires going to the tail light I would trace the wire back to the next area that harness plugs into. Repeat same steps until you work you're way back to the fuze panel. Step1: always start and check the circuit you're working on from the fuze panel with the key in the on position. Many times when you find a short or open circuit the fastest and safest way to fix could be simply running a new wire to feed power, ground, or signal to the component that's not working. Just be sure to isolate the circuit before attempting this.
Mar 06, 2014 | Motorcycles
Proline wiring diagram
You're asking about the circuit diagram to power supply, I assumes, and posts this solution. http://electronicshelponline.blogspot.com/ Check this link. Pull up older posts there. It has schematic diagrams to many popular TVs' power supply's. I can't upload it to you by this window, as it is a PDF document.
Jun 06, 2013 | Televison & Video
I need trace schematic or diagram for power supply board PLCD300PS07
I have the same PS - did you ever get a diagram ? I'm after one too....resistor R100 completely blown so I can't read its value but its either 900Ohm or 100Ohm ?
We might be able to compare symptoms....
Feb 26, 2013 | Televison & Video
Got picture but no sound.
Assuming there are no obvious problems such as TV in mute or something stuck in the headphone output jack then first thing would be to check if the audio IC has a supply voltage, if so suspect the IC is faulty. If not then check the supply line as it's probable a feed resistor has gone open circuit. It may be best to take it to a repair shop if you do not have the necessary equipment to trace the fault.
May 27, 2009 | Philips Televison & Video
Have a whirlpool MH3184XPS-3 and need a shematic wiring diagram
Found a "schematic " diagram of electrical lay out and repaired the associated problem of being mis wired.
May 01, 2009 | Whirlpool MH3184XP Microwave Oven
Polyspan soundstation power supply schematic diagram
My Polycom sound station power unit malfunction. I found that AC transformer broke. If I try to get substitute transformer, what is the required ac output (Vac) and Amp that I need to find?
Nov 23, 2008 | Polycom SoundStation
Dvp 320 no composite video output
CHEEK THE VIDEO SECTION.AND JACK. LATTER OUTPUT DC VOLTAGE FOR VIDEO PORTION.BUT NOT SLOVE THE PROBLEM. SO THE VIDEO CHIP AND CHANGE.
Jan 14, 2008 | Philips DVP320 DVD Player
Vestax Pmc06proa Thin DJ Scratch Mixer System Logo
224 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
