Question about LG WM2277HBW XL Front Load Stackable Washing Machine
Detergent dispenser tray will not open - LG WM2277HBW XL Front Load Stackable Washing Machine
We have been having the same issue - it's possibly the fabric softener blue 'cover' that becomes raised to hit the top of the dispenser unit
we took the top cover off the washer & my husband lifted the dispenser unit lid (as much as possible) and I was able to pull out the dispenser tray
we just removed the cover for the fabric softener so it won't happen again!!!
Posted on Oct 27, 2008
The soap is not being flushed out of the dispenser
Be sure that the detergent tray is not overfilled. If so, it will prevent the detergent tray from opening to dispense the soap. You may want to try liquid detergent to see if it works any better.
May 29, 2016 | LG LDS5540ST Semi-Integrated Dishwasher...
Detergent dispenser
You can drain the detergent tray and clean the tray specially the area where the dispensing nozzle is place, use a air pressure or a jet wash, which must clear the fault as it can be due to dirt accumulation..
Jul 11, 2013 | Washing Machines
My dispenser door sticks. It only comes out about 1/2 inch and then you have to keep opening and closing it that little bit until it comes open all the way. Where is it sticking and how do I fix it?
with the dispenser fully opened, reach in the tray to the retaining clip at the top above the tray. depress clip and fully remove tray. rinse tray to remove dirt and detergent, and with a toothbrush scrub away at interior guide path. use a silicone based lubricant on side rails of the dispenser tray and reinsert, open and close till problem is solved, if problem persists repeat proceedure.
Mar 20, 2011 | LG WM-2277HW Front Load Washer
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Detergent dispenser stuck
Had the same problem here today, the softener dispenser blue plastic piece was loose jamming the whole dispenser tray, to resolve remove top cover, two screws on top rear, slide the cover towards the back, you will then see the detergent dispenser, press the right clips and pull it off slightly at the back; do not put too much pressure and try to remove the cover completely, just pry the plastic cover a bit then pull the detergent tray it should come right out.
Apr 07, 2009 | LG WM-3677HW Front Load Washer / Dryer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a DW12-PFE2-2 the dishwasher tablet does not dissolve,it is still in the dishwasher detergent dispenser after wash has finished?
HI Accumulated detergent from prior washings can cause problems with the soap dispenser. Buildup can get into the soap dispenser and interfere with the spring that triggers the flip-out tray, or it can slow down the pivot action of the tray. If the dispenser is not opening, first make sure you aren't loading the machine so dishes or pots and pans are touching the dispenser, and that dish racks aren't blocking the dispenser. Also check to make sure the dispenser tray isn't cracked. If leftover detergent in the tray is almost liquid, rather than just damp, the tray may be damaged.
If you can't solve the problem easily, replace the entire dispenser unit. This is usually easier than trying to disassemble it and replace separate parts. Use a new dispenser made for the dishwasher. The screws holding the dispenser in place may be on the front of the unit, or you may have to remove the front door panel to get to the screws and make the replacement. Remove the old dispenser and secure the new one, connecting it in the same way the old unit was attached.
THANK U,,,,,,,,,,,,,,,,,,
Sep 12, 2008 | Haier Dishwashers
Front Load Washing Machine
Filling laundry detergent and/or additive
dispensers
Dispenser I: (RIGHT SIDE)
Detergent for soaking agent.
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Dec 29, 2007 | Washing Machines
Dishwasher not cleaning well
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Good luck!
Aug 17, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing Machines Logo
428 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
