Question about RCA L42WD250 42 in. LCD HDTV
Service manual why is so dificult to get service manual for this tv set RCA L42WD22
DONT BUT ONE!I HAVE HAD ONE AND HAVE HAD IT WORKED ONE TWICE IN 4 MONTHS ITS TRASH STAY AWAY!
Posted on Aug 20, 2008
  • 8 Answers
The service manuals are typically only available to service centers unless someone posts it out on the web. i think you can buy them but not sure what the cost is. anything in particular you are looking for?
Posted on Jul 25, 2008
Removing stand flat panel tv
To know more abut this, you should download the repair manual to this set. It's disassemble section will give you all details, with illustrations.
If you wish to get some details, check the site linked here.Pull up older posts.
Dec 11, 2013 | RCA L42WD22 42 in. LCD Television
Cable connection, when I perform channel search no channels are found??? I've tested the cable connection with other tv with no problems. Is it possible that my cable connection is busted on my RCA...
Did select CABLE in the channel scan setting, it should have AIR/CABLE setting so it can look for the cable signal or off the air (antenna) signal.
If you have the setting correctly setup, then the tuner circuits may have gone out. Some TV has the tuner on the main board, it can be expensive to replace the whole main board assembly.
Boards: www.shopjimmy.com
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 05, 2011 | RCA L42WD22 42 in. LCD Television
SOUND BUT NO PICTURE
The two long LCD inverter boards are dead.Replaced the 2 long inverter boards will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long board LCD inverter boards for the replacement.
Jun 07, 2010 | RCA L42WD22 42 in. LCD Television
L42wd22 "no signal" and no audio
Exactly one year ago our TV did that. Now our TV is in the service center cause it has no screen.....just a plain black screen. However last year when we had it in we had that "no signal" message. It was not the same problem. It had something to do with wiring on the master board...thank gosh for warr. Otherwise I was told it would have been a $300-$500 repair.
Best of luck!!
Apr 21, 2010 | RCA L42WD22 42 in. LCD Television
Tv will not turn on
There is a fault condition in the TV. Safety circuit shuts it down.
Check with the authorized service center.
Apr 16, 2010 | RCA L42WD22 42 in. LCD Television
Power light comes on but tv does not screen stays black
Our TV is in the service center right now for that.....it's not pretty. It appears we will be getting a new TV. I was told the part needed is no longer available.
Best of luck
Apr 04, 2010 | RCA L42WD22 42 in. LCD Television
L42WD22 42'' TV sas unusable signal All connections good
We found a solution on another site that did not charge, but thnx anyway.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
May 12, 2008 | RCA L46WD22 Television
RCA service lit avail?
Try Bursma Elect. 1-800-733-3329 ask for Bob and see if he can order it for you . good luck
Mar 07, 2008 | Televison & Video
RCA L42WD250 42 in. LCD HDTV Logo
248 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
