Home Logo
Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tank isn't tall enough to fit the ball **** with a 1 inch difference above the overflow pipe. Is it possible that I have to cut the overflow pipe?
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Feb 17, 2011
Anonymous
Master
Level 3:
Answers
927
Questions
0
Helped
336006
Points
2827
I wouldn't cut the overflow. This is a requirement for proper backflow prevention. Many toilets do not even have backflow preventors on the fill valve. If you try to cut the tube, if you cause other damage, you'll hate yourself.
If you can, set the top of the fill valve as high as you can, the ball float can be at a lower angle to keep the water level below the existing overflow tube.
Gary
How much breathing space does a refrigerator need NONE, 1/2 inch or 1 inch above the top of the cabinet for air circulation. Sears has told me all 3. WHICH IS CORRECT?
For airflow it would be the back that needs clearance of a couple inches. Top of unit shouldn't matter. Inside the fridge itself if you plan on packing it as full as possible except for the amount space needed to allow airflow,. I would just atleast leave 1 inch on every side. But outside of fridge just leave clearance in back and front. Google manual and it will tell you
tip
Building your own ladder golf set
Building your own set for ladder golf is relatively easy and shouldn't take you too long. So you can be up and running in just a few hours.
You are going to need is 1" PVC pipe cut into 6 12-inch pieces and 9 24-inch pieces. You are also going to need 6 elbow fitting, 6 t-fittings. For the balls you are going to need 24 solid golf balls (2 sets of 12 in 2 different colors) and about 28 feet of nylon rope.
To building the ladder to form the base take 4 of the elbow fittings and two t-fitting and the 6 24-inch pipes. Connect the pipes to the elbows and the T's so that they flat side of the T is facing down. There should be an empty socket facing up. When you are finished you should have a rectangle that is 4ft by 2ft with 2 upward facing sockets to hold the ladder.
Next you want to build the ladder. Start by taking one of the remaining 24-inch pipes and attaching an elbow fitting to each end. Then attach a 12-inch pipe to the other side of the elbow. At the other end of the 12 inch pipe you are going to attach a t-fitting, continuing along the plane of the 12-inch pipes attach 2 more 12-inch pipes and in the cross plane attach a 24-inch pipe. Repeat this for the bottom step of the ladder. After you have attached the last pipe fit the open ends into the base and there you have your three step ladder for playing.
To make the balls you are going to need a drill to drill a hole through the center of the 24 balls. After you have drilled the holes in the balls take your nylon rope and measure and cut it into 12 20-inch pieces. It is suggested that you burn the ends of the rope so that they don't fray. Stick the rope through the holes and tie a knot on either side of the ball so they don't move. Put one ball on each end of the rope. You are going to need 6 ropes with 2 balls on each.
Once you have finished making the balls you are ready to play! Some play with each player on their own ladder, if you want to play that way you can follow these instructions again to build a second ladder or you can just use one.
tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 • Plumbing
    Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
    Troubleshoot Your Toilet Without a Plumber
    www.popularmechanics.com/home/how-to/a4117/4303948/
    Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
    Emergencies - Overflowing toilets - Toiletology 101
    www.toiletology.com/emergenc.shtml
    You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
    Nov 19, 2015 • Town Home
    Is there a way to cut an access panel on a 98 Mazda 626 to the fuel pump so I don't have to drop the fuel tank?
    There is a way of gaining access without cutting the floor. You remove the back seat and there are four bolts under the mat if you remove them and lift the fastened cover you will see another cover which has some pipes and electrical socket connector fastenned with small philips screws, if you disconnect the socket , remove the screws and the pipes then lift the unit that is where the fuel pump and the fuel gauge is fitted.
    Fluidmaster instructions
    Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
    Aug 23, 2014 • Home
    The overflow pipe broke off when I was installing a new fill valve. I bought a new flush valve that came with a thick, pink gasket. When I used this gasket, the tank doesn't sit close enough onto the...
    I haven't seen a pink one, but the new gasket should fit over the nut on the new overflow. Keep tightening down the bolts slowly a little bit at a time on each one until the tank doesn't rock. Check on it for a week or two to make sure it doesn't leak. If you don't like the seal that came with the kit, you can buy a different one for a few bucks at the hardware store.
    1helpful
    The overflow valve actually sticks above the top of the tank. Should I cut some of this off? How much?
    If you are talking about the overflow tube in the tank of a toilet, I would say that it should be cut midway between the top of the tank and the high water mark inside the tank.
    The fill valve may even have a mark on the side indicating the high level mark for the backflow preventer.
    Gary
    1helpful
    How do you put this net together? i got it at a
  • Step 1
  • Attach two 8-foot PVC pipes to one of the 12-foot PVC pipes using two elbow fittings and PVC cement. The result will be a short U shape.
  • Step 2 Attach the remaining three 12-foot PVC pipes together using two elbow fittings and PVC cement. The result will be a tall U shape.
  • Step 3 Attach the two U-shaped assemblies together using two elbow fittings and PVC cement. The short U shape is the horizontal base; the tall U shape is the upright frame. The finished result will resemble a bookend
  • Step 4 Cut strips of poultry netting and stretch them across the frame, fastening them with nylon cable ties. You'll find poultry netting packaged in rolls that are 3 feet in width. Cut lengths of the netting to stretch horizontally across the frame, leaving them in the standard width. Start at the top and work down along the back of the tall frame, creating a netted pocket. Overlap the strips by about 8 inches.
  • Step 5 Position the net so that no houses, automobiles or high-traffic areas are behind it. Errant balls can be unpredictable and dangerous.
  • Step 6 Secure the net by placing one 50-lb bag of sand on top of each leg of the practice net's base.
  • Not finding what you are looking for?
    Top Home Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Home Expert? Answer questions, earn points and help others
