Question about Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
This is a combo DVD / VCR unit. I used to be able to program the VCR to "timer record" shows (i.e. program it to turn on and record). This has recently stopped working.
If I simply press "Record" on the panel or remote, the VCR records just fine.
I have had some issues with the TV recently (blown fuse due to a storm), but I have verified the connections, so that is not the issue. I have double-checked the settings on the VCR (i.e. time / date).
It does record, after all, just the timer function seems to have failed.
  • 3 Answers
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Posted on Jul 26, 2008
Can i record data from vcr to dvd
If you want to convert VCR tapes (VHS etc) to DVD discs then your best bet is to buy a second hand combo VCR DVD unit that will make life easier for you.
http://www.ebay.com/itm/dm-40-Samsung-DVD-VR357-VHS-VCR-DVD-Recorder-Combo-w-HDMI-/121234178922?pt=DVD_Players_Recorders&hash=item1c3a1ec36a
Otherwise you can buy adapters that need to be converted to PCs and this can be messy.
This article gives some idea about using PC capture units with software.
http://www.ebay.com/gds/How-to-Transfer-VHS-to-DVD-/10000000177628047/g.html
Aug 28, 2014 | Televison & Video
The manual for my DVD-V3500 says that you can't record from DVD to the VCR. But, can you record from the VCR to a DVD?
In short, no. Not with this unit on its own. No function for recording from or copying to DVDs exists with this brand/model.
A separate DVD recorder is required. I don't know of anyone who records DVDs to tape these days.
You are correct; the manual states clearly you cannot record from the DVD deck in this machine, which is a bit unusual, considering other brands of combos such as LG, SONY and PANASONIC offered an input (which was between channels or could be selected via remote) to allow DVD to VHS recording within the one unit.
I would presume you can connect this combo to the input of a DVD recorder, play a videotape and it will work via cables. DVDs last longer than tapes anyway.
Feb 03, 2011 | Samsung DVD-V3500 DVD Player/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba Televison & Video
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
Samsung BP59-00071B remote wont program Sanyo VCR DVD combo
Try 543. thats what I need to record to my Sanyo VCR via Bell ExpressVu satellite receiver.
Nov 11, 2008 | Televison & Video
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Dish Pro record code for Mag combo
ZNREL, I've done this with Dish Pro before. Setup the Dish remote to control the Mag combo in the VCR position. Press the SAT button and select the guide. Go to the program in the guide and select it. The "record this program" routine should pop up, set it up. Here's the key, make sure the Dish remote has the VCR button selected and that the remote is placed where it can "see" the Mag combo. At the set time, the Dish remote will change the DishPro to the proper channel and then issue s "record" command via infrared to the Mag combo to start recording. DishNet has all of the device codes to their remotes downloadable from their site.
Mar 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Can I connect a dvd player to a dvd\vcr combo
I am not sure I understand why you would hook a dvd player to your combo.You should just hook your magnavox directly to your tv.
Sep 24, 2007 | Televison & Video
Can't record a program with videotape
Try setting the clock again paying close attention to AM and PM settings as well as everything else. REC/OTR is for recording "on the spot". Make sure unit is in proper mode with the DVD/VCR button. Customer service number is usually on a sticker on these units.
Mar 10, 2007 | Sansui VRDVD4000 DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
179 people viewed this question
Henry  Thomas
Henry Thomas
