Question about NEC VT460 Multimedia Projector
Where is it
Where is the   secondry power area is this where the lampis placed
  • 10,594 Answers
No Sir, Main power supply has 2 portion, 1st is called primary and 2nd is called secondary. Primary power area is connected to ac oulet directly and secondry power area is isolated and source of power to projector circuits. Lamp power supply calls "Blast Power Supply" in projectors (Its very high voltage area). Please be careful while testing power supplies.
Posted on Jul 25, 2008
POWER SUPPLY IS NOT COMMING IN THE SECONDRY STSGE THE CHAPPER
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 30, 2015 | Televison & Video
LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | LG 26LG30 26 in. LCD TV
Is not turning on
These sets opperate on what is called a switch mode power supply . that means that the power is electronicaly switched on inside the set after you push the remote or on button . A primary power circuit passes the current thrrough a series of rectifiers and transformers to control the smooth flow of electricty within the set , on the secondry side , the circuit alters the power again via transformers and circuit reducers to go to the different parts of the set the PSU is primarily a distributor .. the noise you can hear is probably the secondry side of the transformer oscilating due to a short or a component malfunction . the short can be in many places within the set especially within the High tension part of the circuit that generates up to 25,ooo volts in some cases per cathode ray tube and most Crt projection units have 3 Red Blue and Green that converge onto one spot to give the primary colours and the picture .
under each tube is the line output transformer this is responsible for generating the High tension it does this by means of an Oscillating transistor usually fitted to a large heat sink near the transformer if these go this will cause the type of fault you describe as the transformer trys to start a squeal is heard ( the tubes trying to charge ) and the set shuts down on most sets the sound circuit will be fed from one of these transformers and will fail at the same time and this is just one possible scenario .. I hope this helps you and must state that unqualified persons who remove the covers of live equipment are at risk of fatal electric shock .. and it is advised that no one without proper training should attempt this . Regards Vortash
May 04, 2009 | RCA HD52W59 HDTV Projection Television
1 second in betweent flash
Thats ok, In my openion, projector has power supply problem. Please open it and check fuses in secondry power area. Atleast one fuse is open there.
Jul 25, 2008 | NEC VT460 Multimedia Projector
Sagem 50" DLP Rear Projection TV fault
Sounds like your lampis going out.
Feb 14, 2008 | Televison & Video
NEC VT460 Multimedia Projector Logo
1,186 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
